Tekno RC SCT410.3 Thread
#766
I pretty much only run emulsion style now but when i was using bladders it was suggested that I use the bleeder hole where the screw goes because then you can use the same caps for all three styles, standard bladder put screw in, vented leave screw out and emulsion put screw in. Hope this helps.
is there an official reason that one cap can't do it all ?
on another note.. besides for adjustability is there any other reason to convert from v1 a, b, c, & d blocks to the V2 ?
#767
Yes, because on emulsion style, the seal is on the bottom of the shock cap to below the threads on the body. With bladder style, the bladder seals the top of the shock cap to the top of the body. This is important because you drill a bleeder hole into the side of the threads for bladder style. If the same cap is used for emulsion, it no longer has a secure rubber seal from letting air into the shock. The hole in the side of the cap just has a couple of threads above it.
#770
#775
Hey bigguyJT ,i was looking at the same combo , look at my post over at rc short course , under moter combo , if u got a second.
NOVAK CRUSHER BALLISTIC 550 4X4 SCT BL SYSTEM (2-3S) NVK3086 this is the one i was looking at,
#776
I finally had some time to start building mine after work last night, got everything done except for the shocks. I'll get those tonight. I must say that this is the best kit I have ever built. The pakaging is organized and neat and each step uses the entire bag of coordinated parts. Everything fits perfectly, even the screws screw in smooth and effortlessly. This is is my 3rd Tekno build and definitely wont be my last. The LCG motor mount makes it pretty hard to get the motor in but it's not impossible. I'm going to run mostly the stock setup except for 5k front diff and Trifex pistons with 35f/32.5r and go from there. Can't wait to get this thing on the track and compare it to my first gen.
#777
You could save a bit of money by just buying the Tenshock 550 4pole. Its the same exact motor, Novak is just rebranding them.
Better to give you something rather than nothing. they could include all 3 aluminum horns, but that would add a significant amount to the cost. Then people would complain the price is too high because they supply 2 extra horns you don't need.
#778
.. if i upgrade towers, arms, hubs and spindles on my v1 do the links need to be changed as well or are the links the same v1 & v3 ?
#780
219Likes
