Tamiya mini cooper
In another note, I think I finally gotten use to the brushless motor driving!
I'm reassembling my M05 and have run into an annoying problem. When I put any tension whatsoever on the forward-most chassis screws (one up by the body mount, the other just behind and below the diff) there is binding in the driveline. Here's a rundown.
- This is the same chassis I've been running without problems.
- I've installed a rebuilt gear diff and it has an adequate amount of side to side play.
- The motor plate is the v.1. I'm testing to see if it runs any smoother than my v.2 when it gets warm.
- New bearings. Properly seated.
It seems as if the chassis is twisting very slightly when these screws are in place. Even the carbon shock tower seems to pull the chassis halves together just enough to create friction. I'm thinking about using a 0.3mm shim between the chassis halves. Opinions?
Out of curiosity, does the binding occur with a stock diff also?????
Unusual problem Jim. Never have seen it before.
I would compare the 2 motor mounts side by side and see how the gear shafts seat in.
Swapped out the motor plate, same deal. Haven't tried the stock diff. I suppose that would be smart.
We've all dealt with this over the years by leaving the screws backed out half a turn. This is just a bit more bind than I'm used to seeing. Stuck a tiny shim in each spot and it loosened up nicely.
got some practice racing in w/ my new M05 V2 conversion. WOW, -the new chassis does handle a lot nicer. The track was a low grip asphalt track, -so ran w/ Tamiya slicks up front and S-Grips on back ...wow, really handled like a dream. Tried both a shorty pack and longer/standard pack, I think I like the way the shorty pack felt better. -plus that gave me some weight savings so I could put extra weight where I wanted.
First race w/ the new chassis is this Sunday, -hope it proves as good as in practice. ...although it will be a higher grip track so not sure if i'll run the same tire setup.
Leaving screws loose is just a half arsed band aid that will shift the problem elsewhere.
It is also possible that the plastic allows the screws to bite deeper and pinch the chassis tighter with use. However, this is just conjecture until you measure the diffs (and perhaps chase other gremlins as well).
295Likes
