Tekno RC SCT410.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree219Likes
Last edit by:
Print Wikipost
Old 04-07-2015 | 10:56 PM
  #196
Jpm1's Avatar
Originally Posted by Monkey#39
trying to figure out the .3 specific parts? arms? are the shock towers different ?
Chassis
TKR5016B – Gearbox (rear, angled)
TKR5049A – Pivot Balls (6.8mm, no flng, sway bar, shck ends, almnm, 4pcs) TKR5052A – Pivot Balls (6.8mm, inside camber, steering links, aluminum, 4pcs) TKR5053A – Pivot Balls (6.8mm, flanged, outside camber, aluminum, 4pcs)
TKR5058A – Pivot Balls (5.8mm, no flange, brake/steering link, aluminum, 4pcs) TKR5079A – Stabilizer Balls (6.8mm, sway bars, aluminum, 4pcs)
TKR5165 * V2 Hinge Pin Inserts, Wheelbase Shims (EB/NB/ET/NT/SCT)
TKR5188 * Rod Ends (6.8mm, M4 thread, SCT/SL, 8pcs)
TKR5212 – LCG Motor Mount Insert (aluminum, gun metal ano)
TKR5260 * CNC Split Cntr Diff Mount (mtr mnt only, 7075, gun metal ano, EB/ET/SCT) TKR5263 * Split Cntr Diff Mount (composite, requires TKR5260, EB/ET/SCT/SL) TKR5288 – Chassis (7075, black anodized, lightened)
TKR5491 * Sway Bar (2.4mm, rear)
TKR5515 * Suspension Arms (rear, SCT.3/SL)
TKR5516 * Suspension Arms (front, SCT.3/SL)
TKR5518B – Front Bumper Set (SCT410)
TKR5541B * Spindles (6x13x5mm outer bearing, L/R, SCT410/EB48SL)
TKR5545 * Rear Hubs (L/R, CV or uni, SCT.3/SL)
TKR5548 – Decal Sheet (SCT410.3)
TKR5554A – Spindle Bushings (SCT410, 4pcs, aluminum, hard ano)
TKR5555A – Arm Bushings (SCT410, 4pcs, aluminum, hard ano)
TKR5570B – Stub Axles (SCT410, hardened steel, 2pcs)
TKR5571M * Wheel Hexes (steel w/ set screw, lightened, 12mm, SCT410/SL) TKR5575X – Diff Coupler (SCT410, f/r, hardened steel, lightened)
TKR5579 * Tapered Driveshaft (SCT/EB48SL, center, front, 7075 aluminum, black ano) TKR5581 * Shock Tower (front, 7075, black ano, SCT.3/SL)
TKR5584 * Shock Tower (rear, 7075, black ano, SCT.3/SL)
TKR5730 * V2 Adj. Hinge Pin Brace Set (composite, EB/NB/ET/NT/SCT)
Diff
TKR5149X – Differential Cross Pins (composite, 3pcs) TKR5614X – Differential Outdrives (SCT410, f/c/r, lightened)
Shocks
TKR6140 * Locking Shock Rod End and Spring Perch Set (EB/NB/ET/NT/SCT) TKR6143 * Shock Boots (medium length, front, EB/NB/SCT, 2pcs)
TKR6144 * Shock Boots (long length, rear EB/NB/SCT, front ET/NT, 2pcs)
Hardware
TKR1215 * M5 Locknuts (aluminum, flanged, serrated, black, 4pcs) TKR1238 * Droop Adjustment Screws (M4x10mm, 8pcs)
TKR1605 * M3x10mm Set Screws (black, 10pcs)
TKR1609 * M3x3mm Set Screws (black, 10pcs)
TKRBB05134 – Ball Bearing (5x13x4, 4pcs) TKRBB06135 – Ball Bearing (6x13x5, 4pcs)
Cheers
Jpm1 is offline
Old 04-08-2015 | 07:32 AM
  #197
does anyone know when these are going to start shipping, I can't wait to get my build on
kyleman7 is offline
Old 04-08-2015 | 07:39 AM
  #198
I might have missed this somewhere but here goes what size are the turnbuckles for the new truck? I have heard the same and that only 4mm rods on all 6? Help please thanks
ben1692 is offline
Old 04-08-2015 | 07:40 AM
  #199
Now!!!
Pete @ fiercercsolutions.com has first shipment on the way now, tracking says they should be at his place Monday. Still 3 unclaimed, might want to get in on those 3. (Mines one of the claimed ones.)
ezlight is offline
Old 04-08-2015 | 12:22 PM
  #200
Woo Hoo!Tekno shipped my new 410.3 today!
ba4ma is offline
Old 04-08-2015 | 12:48 PM
  #201
rjohn929's Avatar
Got one preordered. Think I'm going to give the LRP 10L 4700 a shot and see how it hangs with the 4300HD.
rjohn929 is offline
Old 04-08-2015 | 12:49 PM
  #202
rjohn929's Avatar
Probably. Is that a problem?
rjohn929 is offline
Old 04-08-2015 | 02:03 PM
  #203
Slotmachine's Avatar
Mine shipped out today also, it's going to be a busy weekend.
Slotmachine is offline
Old 04-08-2015 | 03:27 PM
  #204
Curious because I ordered the same Durango aluminum turnbuckles as my first sct410 now Im wondering if the new set I ordered will fit
ben1692 is offline
Old 04-08-2015 | 04:32 PM
  #205
Nick@Jet's Avatar
Already customizing ...jeezz
Nick@Jet is offline
Old 04-08-2015 | 04:53 PM
  #206
King DORK's Avatar
That LRP caught my eye as well. I'll be keeping an eye on this for your results
King DORK is offline
Old 04-08-2015 | 05:00 PM
  #207
Ok, thoughts. I run on a small-med indoor tracks (astro & clay) And about to start the outdoor tracks when they open (hopefully soon) Here are my motor choices. Tekin Pro4 4000kv, tekin Pro4 HD 4300, & hobbywing 4700kv. I have all 3, so it's not deciding on what to buy, just what would be the better choice. I have mod1 pinions 13t-20t
I've ran the 4300HD in my last truck with 15t pinion, but have yet to try the other two.
ezlight is offline
Old 04-08-2015 | 05:05 PM
  #208
to those of you that are running a tekin rx8 gen 2 in your tekno,would the tekin TT3811 100mm sensor cable be long enough to reach from the esc to the motor?i will be hooking it up to a hobbywing 4700kv motor,so i want to make sure it is long enough and compatible.I also ordered a hotwire for it,will there be anything else i need to make this work?This is my first tekin esc and i just wanted to know what parts,adapters i will need to make it work?
ba4ma is offline
Old 04-08-2015 | 05:07 PM
  #209
I was running 50mm, and it was "just" long enough, wish I had just a little more. 100mm should be perfect.
ezlight is offline
Old 04-08-2015 | 05:08 PM
  #210
I already ordered ceramic bearings from boca, aluminum screw kit, aluminum turnbuckles, another m2c chassis, plus all aluminum shock components and carbon fiber parts plus some more stuff I forgot
ben1692 is offline
