Serpent Cobra GT >
Serpent Cobra GT
Like Tree99Likes
Serpent Cobra GT
Old 03-20-2015, 08:07 AM
  #1456
Trader Rating: 17 (100%+)
I have Adobe Reader XI and still showing blank on the setup......I have no idea why.
About the V2 suspension.....if you are running the V1, you can see the shock spring is rubbing against the upper turn buckle. That might be the reason why there is a V2 design. Also, the outer hinge point of V2 is about 2mm longer then V1, thats why they are using the 0mm hex instead of the +2mm hex now. Also it is a longer drive shaft too.
Solara is offline
Old 03-20-2015, 11:18 AM
  #1457
afm
afm's Avatar
Originally Posted by Solara
Yes, you are correct, I have a blank setup sheet as well....may be that is why he is so fast on GT.
blank set-up it is.....PAOLOOOOO!!!
afm is offline
Old 03-24-2015, 09:30 AM
  #1458
KR145's Avatar
I have v1 rear suspension and my shocks dont rub on the turn buckle (but my rear hubs are in forward position).
Seems alot of talk of the New Mugen...Wont see me jumping ship...Lets wake up the Cobra thread.
Its almost Nitro season up here in the NW....I can smell 30% now
KR145 is offline
Old 03-25-2015, 09:20 AM
  #1459
djmorales's Avatar
Trader Rating: 11 (100%+)
Angry throttle & brake setup
Finished my build and just can't get the throttle & brake right.And opinions its becoming quite frustrating.
djmorales is offline
Old 03-25-2015, 01:19 PM
  #1460
mcsquish's Avatar
What can't you get right, what is going on? I know mine isn't exactly like the manual.
mcsquish is offline
Old 03-25-2015, 09:09 PM
  #1461
bring that car to the track, I'll take a look at it
rcmikel is offline
Old 03-26-2015, 11:26 AM
  #1462
dan_vector's Avatar
Trader Rating: 27 (100%+)
It shouldn't be too much of an issue is really straight forward. Post a couple pictures of the problems you are having and I'll try to help.
Set the brake linkage first as that's fixed position. Set the throttle linkage after. Connect it all up to the carb (don't forget a return spring or band around the carb) then move the carb to get it as square to the throttle linkage lever and tighten it all up. Done.
dan_vector is offline
Old 03-27-2015, 07:22 PM
  #1463
Angel Santiago's Avatar
Hi whats the best gearing for the cobra gt to use in kissimme track thanks
Angel Santiago is offline
Old 04-03-2015, 02:54 AM
  #1464
Joseph16's Avatar
Angel start with the factory gearing since you'll use a 5 port motor. 49/45 19/15.
Joseph16 is offline
Old 04-03-2015, 08:55 AM
  #1465
djmorales's Avatar
Cool setup
Went to see rcmikel with the setup was aBIG help thanks guys
Old 04-04-2015, 06:20 AM
  #1466
15/19 Pinions
With Nova 49/45 Spurs
With Picco 50/46 Spurs
desotoracing is offline
Old 04-04-2015, 07:32 AM
  #1467
Photocycler's Avatar
Trader Rating: 36 (100%+)
I have a friend considering a Cobra, what are the must have upgrades out of the box? Do yu guys also run a Buku clutch or is the serpent clutch pretty good?
Photocycler is offline
Old 04-04-2015, 07:47 AM
  #1468
Trader Rating: 358 (100%+)
Save alot money, very low use and has everything needed.
http://www.rctech.net/forum/r-c-item...rts-tires.html
jmoneym is offline
Old 04-04-2015, 09:18 AM
  #1469
tobamiester's Avatar
Trader Rating: 360 (100%+)
Thanks Jermaine
tobamiester is offline
Old 04-04-2015, 09:29 AM
  #1470
KR145's Avatar
The stock clutch is a good but if Ya put in the buku, it's better.
Upgrades most do :
Pro brake kit
Aluminum 2speed holders
10degree or 0 degree c hubs (I haven't tried 0 deg yet but want to )
Aluminum steering knuckles
Black springs all the way arsound
KR145 is offline
