Like Tree256Likes
Tamiya TRF419
Old 03-09-2015 | 10:22 PM
  #1216
Originally Posted by cplus
You will remove the fluorine coating that way!
I've got a muchmore ball cup reamer. Magic.
Flourine wears off anyway.. I'm done buying the fluorine stuff. I just run the blue aluminum stuff for everything else now.
- JV
ittjv is offline
Old 03-10-2015 | 05:18 AM
  #1217
@Art_Mighty's Avatar
Originally Posted by Dusttt
Anyone have a good setup for 17.5 @ tamiya?
Care to be more specific? (Car, surface, traction level, etc...)
@Art_Mighty is offline
Old 03-10-2015 | 05:22 AM
  #1218
I didn't know this existed!
(must...buy...tools...)
Old 03-10-2015 | 08:37 AM
  #1219
Originally Posted by goBezerk
Yeah, mine stripped out too, ended up spinning a nice rebate into the back of the gear. This was on the last race of its first outing, wondered why it went off toward the end of the run!
FWIW an NT1 gear fitted in there perfect, they must have modeled the new gears on them...not going to strip that sucker
so you put a full set of the alum gears from xray in? direct fit? no shimming?
Gordie88 is offline
Old 03-10-2015 | 09:15 AM
  #1220
17.5 set up...
indoor carpet high grip, powers 28 tires, samix aluminum chassis, 1k rear diff oil, standard front and rear toe, shock oil 400 front, 500 rear... yokomo springs, purple front, blue back, camber 1.5 front, 2.5 rear, droop on hudy blocks 5.8 front 4.6 rear, last two screws removed from rear of top deck, protform dart body mounted at 7mm over ground... dialed!
gocoogs is offline
Old 03-10-2015 | 10:28 AM
  #1221
I couldnt wait... local shop has NT1 gears instock... very expenzive... but hey are steel... ill try this weekend and see if they are drop in...
Gordie88 is offline
Old 03-10-2015 | 11:02 AM
  #1222
So the 419 comes with the blue competition o-rings (42137) for the dampers. Has anyone tried the x-rings (42214)? What are the performance differences?
Cheers,
Obsidian is offline
Old 03-10-2015 | 12:00 PM
  #1223
sohlman's Avatar
Cheers,
I did not try them, but during the build I noticed the 419 shocks have a new plastic rod guide that molds to the contour of the o-ring. The x-ring would most likely get deformed and may cause leaking…not confirmed though.
sohlman is offline
Old 03-10-2015 | 12:45 PM
  #1224
I too noticed that during my build. I don't have any X-rings so I don't know if they are rounded on either side like the comp o-rings. I was just curious about the x-rings performance with respect to the comp o-rings.
cheers
Obsidian is offline
Old 03-10-2015 | 06:18 PM
  #1225
Cheers,
Funny you should ask. I actually did install the x-rings and the car does feel great with them but i do suspect there's a little more stiction with them.
Old 03-10-2015 | 08:39 PM
  #1226
goBezerk's Avatar
I just used the steel main gears (I had some lying around from other projects) and the Tamiya small gears. I did replace the shim, I think this was the main cause as it had distorted. I don't recall the actual thickness of the one I used, large diameter like the gear itself, probably around 0.3mm.
Edit: Pretty sure the whole lot would fit, I didn't think it was necessary so only fitted the larger primary gears.
goBezerk is offline
Old 03-11-2015 | 05:34 AM
  #1227
The NT1 gears are slightly thinner... so shimming will be required... the Local shop didnt have the graphite ones in stock... the steel ones are much heavier then stock... but id rather finish the run...
Gordie88 is offline
Old 03-11-2015 | 07:34 AM
  #1228
TryHard's Avatar
Are you guy hitting things with the diff stripping... because I've had four meetings on my car now, and the diff has been faultless, with the exception of a bit of outdrive seepage (it's not really leaking IMO, as there is still A LOT of oil left in the diff). And that is full bore mod, and a fair few decent hits (one broke the rims on the rhs wheels, the other broke the servo!), and no issues..
TryHard is offline
Old 03-11-2015 | 07:57 AM
  #1229
lots of meetings with mine now and no issues with any off it. (Although just 13.5 boosted or blinky).
Qatmix is offline
Old 03-11-2015 | 08:01 AM
  #1230
sohlman's Avatar
+1 - Ran mod on Sat and 13.5 on Sunday. Took a couple of good hits, broke suspension parts, but the diff is perfection. No leaking, no reduced diff action, heck the V5 blades even stayed in tact.
sohlman is offline
