NEW Serpent 12th scale >
Old 01-29-2015 | 04:55 PM
  #31
bigcracing's Avatar
I want two right away. When are they avalible?
bigcracing is offline
Old 01-29-2015 | 05:26 PM
  #32
Default observations
The new rear pod's center pivot does look to be a novel approach that could potentially achieve a self-adjusting and bind-proof pivoting action. If indeed it does pivot freely and it also proves to be durable enough, then Serpent's new and unusual center pivot could turn out to be really nice feature. Having said that, their unique center pivot design also looks like it could be a potential weak point. Time will tell if their unusual pod design turns out to have more plusses than minuses. With the front shock mount as shown, it appears that the new car is designed to run a transverse battery, but oddly there also appear to be slots in the main chassis that hint at an offset inline battery orientation. Hmmm. In any event, I don't see anything that would position the battery either front-to-back or side-to-side. Surely Serpent must have a method in mind for positioning the battery, but such is not apparent from the posted photos. Perhaps the pics are of an early and not yet fully developed prototype ??
vafactor is offline
Old 01-29-2015 | 05:49 PM
  #33
wingracer's Avatar
I see several holes where bolts/nuts can be placed for a forward transverse position or an offset inline and then tape slots to hold it down. That's all you need. And since it lacks esc and receiver, it's obviously a build, not a race ready set-up.
wingracer is offline
Old 01-31-2015 | 11:55 AM
  #34
Julius's Avatar
The new pivot is quite tough. I can attest to that having run a pre production car yesterday 😄. The pivot is absolutely free and stays free even after crashes......
After getting the hang of 1/12 again I set a new personal best laptime.
Battery will go longitudinal and transverse. For both positions stops can be screwed in the chassis. The longitudinal slots are countersunk to adjust forward stops for transverse, and two dedicated holes are in place for longitudinal placement.
The new front end indeed has inserts for kingpin inclination and is a more conventional setup on the top pivot.
It is funny that many dislike the center shock, while yokomo puts it in their 1/12 kit....
Julius is offline
Old 02-01-2015 | 12:47 AM
  #35
LKF
i am a little disappointed about so called "innovative rear pivot system"
but new serpent car looks nice as always.
LKF is offline
Old 02-05-2015 | 08:34 PM
  #36
jason cheng's Avatar
http://www.serpent.com/product/410006/images/
jason cheng is offline
Old 02-05-2015 | 11:17 PM
  #37
The-Border is going to ship it coming Tuesday or Wednesday.
Thaan is offline
Old 02-06-2015 | 09:50 AM
  #38
They do try something different. Don't know if it's going to be better, but it's definitely an interesting approach to the pivot ball.
Martin Paradis
rhodopsine is offline
Old 02-06-2015 | 12:18 PM
  #39
dr_hfuhuhurr's Avatar
What springs does the shock use? Associated or Serpent only?
dr_hfuhuhurr is offline
Old 02-06-2015 | 01:09 PM
  #40
chris moore's Avatar
If your asking about the stock shock it is too large around for AE springs and you must use the Serpent springs. Some ditch it for a more standard sized shock.
chris moore is offline
Old 03-02-2015 | 06:11 PM
  #41
Really, no one else is pivoting from the top cross brace. Already have mine built will all orange aluminum.
Steve
sdunnmcp is offline
Old 03-02-2015 | 06:52 PM
  #42
Steve
I was thinking the same thing...it may look like a minor change but it really is quite an innovation. It is still pivoting from the lower part of the chassis but the additional pivot in the upper brace allows the whole thing to move without binding and stays much more free.
I've been toying with the idea of getting a custom chassis plate and rear pod plate cut so I can incorporate all the different parts I like best in the different cars on the market.
InspGadgt is offline
Old 03-02-2015 | 09:40 PM
  #43
RedBullFiXX's Avatar
Sweet new car
Serpent always have such a nice design too
RedBullFiXX is offline
Old 03-04-2015 | 02:54 AM
  #44
Thaan is offline
Old 03-07-2015 | 11:15 AM
  #45
Originally Posted by Thaan
Anyone know when these will be available?
Crashby is offline
