New REDS Racing M3T .12 Engine! >
Like Tree1Likes
Old 05-17-2014 | 12:11 PM
  #76
Default Caburator
Hi
Have one of these fantastic engines , but have a problem with the reds caburator , it leaks a lot. And its very difficult to adjust. Have heard that people change to nova caburator.
Any ideas , maybe setting it back to factory setting if anyone know.
johnsen-dk is offline
Old 06-10-2014 | 03:55 PM
  #77
D-nicest's Avatar
Originally Posted by johnsen-dk
Hi
The carb doesnt really leak, the moisture comes from the raw vapor in the venturi when the engine is being ran. depending on how rich you run, it builds up in the lip of the filter and slowly leaks down onto the body. Never tried a nova carb, but I really haven't seen a need for it. My question for you is if your having tuning problems, what percentage Nitro, whats the combustion chamber set at, how are you geared, and whats your clutch set up? The motors make a ton of power so they are extremely clutch sensitive. Try starting flush on the top end and about a turn out from flush on the low end. Also make sure your getting full throttle out of your servo because even if the carb window is open to the eye, on this motor u still have about a 1/4 more to go on the epa. Basically set it so that you cant pull the slide out any further by hand...
D-nicest is offline
Old 06-11-2014 | 05:33 AM
  #78
kickass's Avatar
Hi
Run a Nova Carby, "ALL" your problems solved right there.
kickass is offline
Old 08-22-2014 | 08:35 PM
  #79
jimlazaro's Avatar
Hi guys need advice or help for this engine. The engine was team tuned.
What the safest or best head shim to run 20% nitro byron fuel?
Right now I put total of .45 shim.
But I didn't run it yet.
Pls. Help, advice thank you.
jimlazaro is offline
Old 08-25-2014 | 09:03 PM
  #80
jimlazaro's Avatar
Ok since nobody reply to my question. Here's my other question I hope someone will reply.
What's the stock head shim on this engine?
Old 08-26-2014 | 01:46 AM
  #81
RC-Netshop.dk's Avatar
Hi Jim,
You normally add 0.1m shim if you go up from 16%-25%, so if you are running 20% then you are on the safe side with 0.1m. It also goes vice versa.
Br,
Niko
RC-Netshop.dk is offline
Old 08-26-2014 | 01:49 AM
  #82
I will check mine and revert, but as I remember my WCS has 0.3-0.35mm head shims and 0.1mm under sleeve. My old M3T which has awesome bottom power has no shim under sleeve.
Br,
Niko
Old 01-19-2015 | 01:44 PM
  #83
1evo RRR Driver's Avatar
Fellas quick question........are their 2different sizes of picco.12 motor to pipe coupler?? I was at the track yesterday n couldn't get a picco pipe on my edo motor.......seemed like coupler was to thick.
1evo RRR Driver is offline
Old 02-20-2015 | 08:50 PM
  #84
markiemark's Avatar
Hey new to red engines but picked up a nt1 with a Reds m3wc. How often should the rod be replaced?? And the rod is the same as the m3t??
markiemark is offline
Old 02-20-2015 | 10:01 PM
  #85
yea it is the same rod i like to change the rod every gallon or so depend how hard u going to run the engines
Fernalva is offline
Old 02-23-2015 | 05:49 AM
  #86
Smile Sorry for interupting
Does someone know if a new 21. is coming out anytime soon?
Thanks!
Koceto1999 is offline
Old 02-23-2015 | 10:19 AM
  #87
wmay11's Avatar
Yes they have the Reds WCS Red Edition out.
We are busy running them in at the moment.
I am sure 2015 will see another wcs black head, but dont think there will be changes to internals.
wmay11 is offline
Old 02-23-2015 | 10:24 AM
  #88
wmay11's Avatar
One gallon is too soon, 2 gallons is still safe..
In on road we have run over 11 gallons on wcs .21 with one rod change and original bearings. Not advice to follow, but we have just seen these motors go and go and go, eventually just not bothered if it blows since you running the same engine for two years.
wmay11 is offline
Old 02-23-2015 | 10:59 AM
  #89
Smile
Thank you for the answer, sir! I'm very pleased with REDS products.
Old 02-23-2015 | 06:50 PM
  #90
markiemark's Avatar
Thanks for the info I'm just getting back into it and the car I picked up has a m3wc was told its a fast motor and has just over gallon on it. Will there be a new .12 this year?
