New REDS Racing M3T .12 Engine!
#91
WC is already replaced by the WCS :-).... But basically the change is shims under the sleeve, WC has no shims, WCS has a 0.1mm shim... Gives you a little more high end RPM, with a little sacrifice on the low end torque....
#92
Are you sure that wcs has 0.1mm under and not 0.3mm?
1Likes
