Can someone explain...
Old 02-11-2005 | 07:27 AM
purpurite's Avatar
Default Can someone explain...
...exactly what an SG crank is, how it differs from a standard crank, and what the benefits or uses would be? What wouold require the use of an SG crank?
Thanks,
doug
purpurite is offline
Old 02-11-2005 | 09:50 AM
uaerc's Avatar
As far as i know SG crank is a longer one and the abbreviation 'SG' just represents the size of the crank.. An SG type crank is used in almost all touring cars... as its a bit longer.....
The other threaded type is usually used in trucks etc...
I dont think it has anything to do with performace... correct me if i am wrong ppl......
uaerc is offline
Old 02-11-2005 | 02:33 PM
soc123_au's Avatar
The SG crank is less likely to be unstable at higher RPM, The reason is the clutch & bell are attatched to the crank directly. On a threaded crank the clutch is attatched to a pilot shaft (long flywheel nut) being 2 peices give more chance of vibration etc.
soc123_au is offline
Old 02-11-2005 | 05:45 PM
jag's Avatar
jag
An SG shaft allows the use of a 2-speed clutch without having to use a pilot shaft/nut which, as previously stated, is not the best for several reasons. I do not believe the SG shaft makes more power but I do think most companies use an SG shaft in their best engines.
jag is offline
