Tekno NB48
#3046
Jim,
This is what I use and it is great fuel line. Comes in a plethora of colors and is available at most hobby shops.
http://www.amain.com/du-bro-nitro-li...ue-61cm/p13003
#3047
Jim,
#3048
Is it just me, or does the kit fuel line seem slightly smaller in the OD than what some of the fuel line I remember buying in the past. Not trying to over think this, just want to make sure that the replacement fuel line will easily feed through the hole in the tank, properly seal at that hole and not get overly squeezed, restricting flow.
I've got about 2 flawless gallons on the kit fuel line. Is still holding up, but would like to replace it and not have to troubleshoot any abnormalities by something as simple as this.
#3049
From my experience, the ID of the Dubro line is the same, but the OD is slightly bigger. It still fits snugly in the tank, but not so much that it pinches it off. It also has a nice firm hold in the line mounts as well.
#3050
And I agree, the clear/translucent blue is the way to go
#3051
What's the deal with the new shock cap bushings? Building both the NB48 and EB48.2, and they both are the same. They just compress into the shock cap and never "free" up, tightening them down on the standoff, they're practically locked up. I've built many kits over my years and I can't figure it out. My early run SCT410 with the old/plastic caps is fine.
NVM. Found it. http://www.rctech.net/forum/13130828-post1045.html
Different question, which sides do the new lower shock bolts go? Silver (lefthand thread) on right front and left rear?
#3052
http://www.teknorc.com/shop/tkr1240-...reads-ebnbsct/
#3055
#3058
Oh, i got basic idea:
imagine rotation coming to screw from shock while suspension is being compressed. Direction of that rotation must tighten screw, not loosen it. So for NB, Black (CW) goes to tank side and switch side, Silver (CCW) goes to st.servo side and exhaust manifold side.
#3059
#3060
Long time Kyosho driver. I have also owned a couple of EB48's. I'm excited about building this NB48. I got a couple of questions....didn't want to bother my team manager. What size is the flywheel? Rear motor position not very popular? What is the equivalent to Tekno 450 or 350 oil...and the Tekno diff oil? I don't think Tekno sells oil. Good starting point box set-up or Lutz Fall Brawl or Battle of the Sickest? 6 washers on Ackerman popular?
Thanks ahead of time. I am sure I will have more questions.
12Likes
