Tamiya TRF419
#736
Received the Samix alu and carbon chassis' a few days ago. Here are the weights:
- Stock TRF419 carbon: 70.9g
- Samix TRF419 carbon: 70.2g
- Samix TRF419 aluminium: 102.7g
- Samix TRF419 aluminium with battery and fan mounts: 118.2g
More on the Samix 419 alu and carbon chassis; http://kentech.blogs.se/
#738
Is anyone changing out for different ball studs and ball cups? Mine dont seem to be super "free". I dont know if it even really matters and i assume that they will free up after some use.
#742
I'm going to use fluorine coated ball cups throughout for this build - will report back if they are nicer (but I didn't notice the old one being bad)
#743
I did. Weird thing they are good in the rear. Fronts are snug
#744
The (plain/blue anodised) Aluminium (or steel) ballstuds are a fraction smaller than the fluorine coated ball ends hence a little loose in the cups. The fluorine coated are perfect (no play, whilst free to move). Maybe the fluorine coating makes the difference.
#746
#748
Anyone using an aftermarket o ring on there shocks? My shocks seem to be leaking a little more than my 418 ones did and i am not sure if i used different or kit o rings on that car.
If so part number would also be good.
256Likes
