need help with rx and tx lipo
I believe the C rating is what the battery is capable of putting out in amps. As long as your radio is rated for the voltage of the battery you'll be fine. Radios don't pull a lot of amps so they don't need a high output battery but it won't hurt it if you use one.
no his radio doesnt but if the voltage is fine for it go ahead it will only pull the amps it needs the battery doesnt push amps the thing it is plugged into pulls them
The radio is the airtronics MT4. I have a protek lipo in the receiver, it has only 8c, I can use it in the radio, but the question is if I can use the other battery (25c) in the receiver, my servos are hi voltage.
