Team Associated TC4 >
Team Associated TC4
Like Tree300Likes
Team Associated TC4
Old 12-29-2014, 06:52 AM
  #13276
Robert421's Avatar
Trader Rating: 11 (100%+)
Originally Posted by Shano1
Yeah plus it holds the centre shaft in place, any suggestions?
Are you trying to fix up a FT TC4? You might find a roller for sale and buy it that way. I could not find the part.
Robert421 is offline
Old 12-29-2014, 07:04 AM
  #13277
moparSRT's Avatar
Finding one of these is like winning the lottery
moparSRT is offline
Old 12-29-2014, 08:52 AM
  #13278
Robert421's Avatar
Do you have the winning lottery ticket? Shano1 wants to buy one
Old 12-29-2014, 09:32 AM
  #13279
NutDriver's Avatar
Trader Rating: 30 (100%+)
Xtreme R/C has/had TC3 motor mounts that also have a bearing carrier for the drive shaft. Penguin R/C sells an adapter to support the stock bearing carrier when used on a non-tub chassis.
NutDriver is offline
Old 12-29-2014, 09:37 AM
  #13280
NutDriver's Avatar
I'm really looking forward to getting my hands on YoDog's chassis that he posted pics of on page 881.
Old 12-29-2014, 10:51 AM
  #13281
RotorTruck's Avatar
Originally Posted by tmail55
So, changed the inner link ballstuds F/R to #6276 (.200) these are shorter in height than the stock ballstuds about .020-.030.
Then on the front ballstud at the c-hub put on one #9630 ballstud washer.
The old timers will remember, that adding or not a ballstud washer was tuning option on the B3/T3's front outer link mount.
The TC4 has NEVER been this steady on the track.
TQ'd / 1st >> lapped the entire field.
If you can post your entire setup here, including what tire used and class I'd be grateful. Always looking for a fast asphalt setup for TC4 VTA or at least rubber tire.
RotorTruck is offline
Old 12-29-2014, 11:31 AM
  #13282
Exclamation
+1
THEBIGBULL is offline
Old 12-29-2014, 12:12 PM
  #13283
Robert421's Avatar
have you heard anything from that chassis?
Old 12-29-2014, 01:25 PM
  #13284
tmail55's Avatar
Trader Rating: 61 (100%+)
Mod TC from last Sat (12/27/14)
http://www.t3t4webservice.com/tc4-Terrance.pdf
TC4 build history >>> http://www.rcten.com/threads/terrances-tc4.12624/
IF you race VTA don't do the B3 axles on the rear.
tmail55 is offline
Old 12-29-2014, 02:08 PM
  #13285
RAL
RAL's Avatar
Trader Rating: 67 (100%+)
Hi Terrance,
When you note 4 or 5 for the suspension mount shims does that mean the total height in mm of the shims or the number of shims? They come in two diff thicknesses right? 1 tab and 2 tab markings? Or is it total number of tabs? Like two, two tab shims and one, one tab shim makes 5? Just trying to understand your roll center.
-R
RAL is offline
Old 12-29-2014, 08:02 PM
  #13286
tmail55's Avatar
Originally Posted by RAL
Hi Terrance,
-R
The "0" mount has a shorter height compared to the "X" mount so you have to put more shims in equal the "X" height. The "0" mount is used to reduce the rear 3 degrees to 2 degrees.
Each "tab" is worth .025 shim thickness (per the TC4 manual).
The asphalt tracks are either sealed (100% traction) or soda treated (100 to 90% traction) that I'm racing on.
I'm a off road guy (9 years) who has two on road RC's (7 months). So I don't think about roll center, FDR, or traction roll cause that's not very useable info for off road.
New tires, a spacer added or removed at the links or wheelbase and I'm good. I do look at setup sheets that best fit the tracks, compare each to the others to get a base setup and work from there.
tmail55 is offline
Old 12-29-2014, 08:23 PM
  #13287
Shano1's Avatar
Post
Do you have the winning lottery ticket? Shano1 want to buy one
Unfortunately i don't have the winning lotto ticket 😢 but if you willing to post a winning ticket that would be awesome 😆
Shano1 is offline
Old 12-30-2014, 10:58 AM
  #13288
YoDog's Avatar
Trader Rating: 28 (100%+)
Had a fun day of practice/testing at our local outdoor track. I worked on different tires, motors and bodies to get a feel for the differences in handling. The car worked really nice. (Sorry that I don't have video yet) Once again, many of the drivers took notice and asked what chassis I was running. Still making some minor tweaks and finalizing the CNC programming but the holidays are taking some time away from making quick progress. I will likely make two versions of the chassis. One with the mounting points for the side braces and one without. I want to do some shorty pack testing next time out to establish a good balance with weight distribution.
Attached Thumbnails Team Associated TC4-20141218_213420-800x600-.jpg   Team Associated TC4-20141218_230318-800x600-.jpg   Team Associated TC4-20141218_230343-800x600-.jpg
YoDog is offline
Old 12-30-2014, 11:20 AM
  #13289
RotorTruck's Avatar
Hi Terrance, thanks for sharing the setup! If you don't mind me asking, what's the idea behind running 0* castor up front, I never heard of that before. Is the car stable and doesn't wander on the straights? Is there enough camber gain thru the turn?
Also, all the hing pin spacers, is that to raise the inner end of the lower a-arms so they'll be parallel to the ground due to the low ride height? I've always questioned running any angle on lower a-arms. In my autocrossing experience, my truck (yep truck) always handled better when the lower a-arms were parallel to the ground, even better than if the truck was lowered more because that caused the a-arms to angle up.
I would guess that after adding all the hing pin spacers, the upper inner links needed to be lowered to make the upper links parallel to the ground (or parallel to the lower links). ?
Thanks again, congrats on the TQ and win! The setup is obviously working :-)
Old 12-30-2014, 02:23 PM
  #13290
Robert421's Avatar
looks good, let us know when it is available
