Like Tree2Likes
Tamiya TRF418
Old 09-14-2014 | 10:12 PM
  #1786
hanzo3's Avatar
Tamiya also makes titanium turnbuckles in that tamiya blue as well.
hanzo3 is offline
Old 09-14-2014 | 10:48 PM
  #1787
niznai's Avatar
Yep, they do, but they're overpriced and crap. I never managed to bend/break a Ti rod from anyone else apart from Tamiya.
niznai is offline
Old 09-14-2014 | 11:42 PM
  #1788
Simmi's Avatar
You can also use turnbuckles from Associated different blue but Titanium TA 1401 FT 33mm.
Marc R also use this turnbuckles
Yesterday I drive with the EVO 6 Servo Mount. I change also the blocks in front to B-B. I think I have more steering, find not such a big difference.
Simmi is offline
Old 09-15-2014 | 12:23 AM
  #1789
hanzo3's Avatar
Thanks. They only cost $6. Why by overpriced Tamiya ones?
hanzo3 is offline
Old 09-15-2014 | 12:40 AM
  #1790
niznai's Avatar
Or just get some Lunsford turnbuckles. I found they're the best quality, ever reliable and can get any size you'd like.
Yokomo sells Ti turnbuckle kits for their cars under their brand, but they're made by Lunsford. You might be able to get one of those kits easier.
niznai is offline
Old 09-15-2014 | 06:08 AM
  #1791
I like this idea. I like Lunsford from my off road days. I will have to search for the Yok set if they are the right sizes.
Thanks for the help.
goin2drt is offline
Old 09-15-2014 | 06:12 AM
  #1792
That's what confused me. Coming from AE the Tamiya seemed similar so I assumed they were Ti.
goin2drt is offline
Old 09-16-2014 | 12:38 AM
  #1793
Salkin's Avatar
In the 418 setup sheet, like this one:
http://www.petitrc.com/reglages/tami...ice2013110103/
In the bottom, to the left, there is a setup parameter "Lower deck 2.25 mm".
What is that?
Salkin is offline
Old 09-16-2014 | 12:52 AM
  #1794
niznai's Avatar
What is that?
Lower (main) chassis plate thickness.
Pretty much standard these days, but in the days of yore there were thicker plates for instance for on-road foam tire racing where stiffer chassies made sense.
niznai is offline
Old 09-16-2014 | 01:02 AM
  #1795
Salkin's Avatar
Ah, OK. I just use the kit lower chassis plate, so I can "ignore" this parameter, as I can not change it anyway.
Salkin is offline
Old 09-16-2014 | 01:51 AM
  #1796
niznai's Avatar
Xray used to have up to the T3 "foam" (or US-spec) chassies and Euro (or rubber spec) kits where the main difference was the chassis (3 vs 2.25mm). Not sure if T4 has these options.
niznai is offline
Old 09-16-2014 | 06:26 AM
  #1797
Salkin's Avatar
Does anyone have a neutral, non aggressive, setup for indoor carpet track?
I run on this track:
http://www.youtube.com/watch?v=0qCAXiC8LTM
I run 4.5T modified. Sorex 28. LRP carpet grip additive.
I currently run kit setup, coming from an outdoor track.
I have just purchased HPI Silver (black colored) springs. Are these better to use than the kit springs that I currently use on indoor carpet?
Salkin is offline
Old 09-16-2014 | 06:36 AM
  #1798
sosidge's Avatar
If you want it to be non-aggressive then you want to get rid of the 4.5T motor.
For setup, start with the outdoor setting. I never really got a nice setup on my 418 last season so can't advise, I ended up running HPI Pinks on the front and HPI silvers on the rear, #2,000 in the rear diff, but always struggled with rear traction no matter what I tried. And that was with a 17.5.
sosidge is offline
Old 09-16-2014 | 07:01 AM
  #1799
Salkin's Avatar
Well, it is actually my 10 year old son who drives the 418, and the power control is not a problem. his gearing is 7,66 (116/28).
By non aggressive I mean a car with relatively neutral steering and a non twitchy car. I rather start with a neutral setup and then add some steering etc. if/when needed.
I run an older 417v5 with a 4T Speed Passion motor, and even though I'm new I don't think the power is too much. I know many thinks it is crazy powerful, but I really don't think they are that powerful. Not trying to sound smart or anything.
We come from 1/8 E buggies and are use to overpowered buggies racing on loose dirt, so careful trigger operation is the name of the game.
Compared to this running TC on carpet is like running on rails. You turn, the car actually turns, you brake and the car actually brakes. It seems so much more tactile.
Salkin is offline
Old 09-16-2014 | 06:50 PM
  #1800
JimmyMac's Avatar
Have you tried running Marc's first 418 setup from the ETS races? http://www.petitrc.com/reglages/tami...ice2013110103/
I tried this setup on our local track with kit springs and it's been doing pretty good. Just needs more work for my driving style.
JimmyMac is offline
