Like Tree2991Likes
1/12 forum
Old 09-09-2014 | 08:52 PM
  #41326
DesertRat's Avatar
The bronze ones from CRC are not as good as their plastic ones, they seem to bind more easily. I swapped back to the plastic.
DesertRat is online now
Old 09-10-2014 | 01:33 PM
  #41327
Stick to the plastic ones. Despite lots of effort over many years, no one has come up with anything that matches the performance of the plastic ones. The lowest friction is with the plastic ones, anything else raises friction and compromises handling.
Make sure you lubricate the kingpin with enough silicon fluid to prevent the dirt getting in - a smear will do the trick - and they will last a long time. If you don't like damping on your front pins then use a 3000wt oil. Clean out everything thoroughly and re-lube after every meeting to maintain the performance of the suspension.
The fit in the socket can be fixed with a smear of superglue on a cotton bud if too loose, and if the kingpin or socket fit is too tight, select another ball. Metal ones will not fix those fit issues. HTH
SlowerOne is offline
Old 09-10-2014 | 02:10 PM
  #41328
noline's Avatar
Anyone have a Trinity 13.5 D4 and 17.5 D4 1/12th Blinky setup? Need gearing and timing setup for a 100 foot track
noline is offline
Old 09-10-2014 | 02:15 PM
  #41329
durtbag's Avatar
Originally Posted by oreo
I've briefly peeked at the Oval racing websites(Rc4Less.com,Ovalstuff.com, LefthanderRc), and also TeamIRSRC and also TeamCRC......some of the options are teflon coated pivot balls , the standard # 8417 ones (plastic Associated parts) and the Bronze pinch-proof ones from CRC. I've stuck with the standard issue # 8417 pivot balls. Good luck with your choice.
Thanks, to those that replied! I think that I just needed some reasurrance that the plastic ones will work just as well. I find that checking for looseness of the pivot ball (up and down) in the lower arm and replacing the arm as required is all that is needed. lubeing the kingpin is done as well.
Thanks, Terry
durtbag is offline
Old 09-10-2014 | 07:03 PM
  #41330
Originally Posted by durtbag
12R5.2, all I find listed are the #8417 plastic version. But I have steel ones in my 12R5.1 (hybrid with tubes), and I'm sure they came in the kit. I would like to use these in my new OP12C as they are much smoother.
Terry
What parts did you use or kit to put tubes on your 5.1 as I have a 12r5 and a
12r5.1 and would like to put tubes on one of them.
magnum is offline
Old 09-10-2014 | 07:12 PM
  #41331
Whats a great all around 1/12 chassis to start back to racing? Sorry I tried CRC car and i wasn't a fan! How is the rev8 or the new top car
racer034life is offline
Old 09-10-2014 | 07:17 PM
  #41332
Peter Martin's Avatar
Yes on the Rev8 or TOP.
Peter Martin is offline
Old 09-10-2014 | 07:18 PM
  #41333
TOADYY's Avatar
I went from my Serpent to the Rev 8 Pro and found it was more stable with more corner speed. So far I really like the Rev 8.
TOADYY is offline
Old 09-10-2014 | 09:15 PM
  #41334
RedBullFiXX's Avatar
Anyone have a Team Prime shock they can weigh ?
Curious what the weight is, without spring
Thank you
RedBullFiXX is offline
Old 09-11-2014 | 05:18 AM
  #41335
DaveVera's Avatar
Moderator
Thank you
Mine weighed in at 4 grams without the spring....
DaveVera is offline
Old 09-11-2014 | 07:55 AM
  #41336
durtbag's Avatar
I used:
1 x 4703 Upper Pod Plate
1 x 4704 Chassis Brace
1 x 4707 Side Sprig Retainer
1 x 4708 Damper Tube
1 x 4709 Damper Tube Shaft
Terry
durtbag is offline
Old 09-11-2014 | 08:06 AM
  #41337
Rugspin's Avatar
Ran Last night at TQ still working on Timing on the motor
Trinity D4 40-50deg
Spur 76
Pinon 50
Tires 46
Roll Out 95.07
Going to try decreasing the timing and gearing up a bit...
Rugspin is offline
Old 09-11-2014 | 05:18 PM
  #41338
rtypec's Avatar
Thank you
Doesn't it depend on the weight of oil your using?
rtypec is offline
Old 09-11-2014 | 06:53 PM
  #41339
Thanks Dave, good luck at the worlds
Actually, there is no measurable difference in weight, regardless of Viscosity
Old 09-11-2014 | 09:25 PM
  #41340
what size diff balls are used with the kimbrough spur gears
goots is offline
