What servo you using?? >
Old 07-11-2014 | 08:26 PM
timritchieblue's Avatar
Default What servo you using??
Looking for a MONSTER TORQUE servo?? Want something in the 300oz PLUS range. Hitec 7955,7954, ?? Would love to stay under $100??
timritchieblue is offline
Old 07-11-2014 | 08:41 PM
Kamitiro Fan's Avatar
Hitec HS-7955TG Ultra Torque is a beast
Kamitiro Fan is offline
Old 07-12-2014 | 09:48 AM
JimmyG's Avatar
I race Clodbusters on carpet, and needed a high power servo. I came across OMG servos, and have been using them for over a year now. I told Tony my application, and he sent me this one. HDT065150B.
I have never seen a servo turn clod tires like this. Ive used Spektrum, JR, and Airtronics.. WOW!! It is amazing. My times decreased, and I got to drive more aggressive since the servo wasn't slowing me down anymore, and I still use a servo saver even tho Tony told me not to use one. The rated oz is 208 at 6.0v. yea.. Its more like 300!!! I do use a Castle BEC to power my servos, just makes sense.
OMG is getting more popular in America's and for the cost, its worth it. If you want to try something different, they are the way to go.
They are on FB as well if you need to contact them.
JimmyG is offline
Old 07-14-2014 | 09:20 AM
They're an awesome servo! But the same price ($99 Amain) you can get the Hitec HS-7954SH instead. Basically the same servo with the same 333oz @ 6.0v rating but is rated for 7.4v with over 400oz! I run a HSR-5980TG which has the 7955's titanium gears but is HV capable with the same ratings as the 7954 and a slightly different case. I run that sucker in a LST XXL without a servo saver and it takes anything I throw at it.
Running an external BEC is a must to get the most out of a servo. I've tested servos for amp draw and saw average draw around .75amp with spikes over. 1amp. I went from an internal esc Bec rated at 5amps to the 10amp Castle ( set to 6.0v) and saw a very noticeable performance increase that was well worth the price and effort. Things only got better when I set it to 7.4v!
Overdriven is offline
Old 07-14-2014 | 02:51 PM
Was about to pull the trigger on another HiTec....but I thinking about a Savox 1231 with cap, and Al. Arm $75 shipped..hope it works as good as the specs...
Need help with BEC OR EXT RECEIVER BATTERY? Suggestions ?
Old 07-21-2014 | 11:36 AM
http://www.ebay.com/itm/Savox-SC-123...item3390e55679
500oz on 6v. Hard to beat.
jrowles91 is offline
Old 07-21-2014 | 12:55 PM
I'm running hitec 5645 servos in all my 1/8 scale stuff. With the cam style servo saver mod in my savage ss it's spot on.
Tug Driver is offline
Old 07-21-2014 | 03:06 PM
Thanks for the replys,, bought this one.
Old 07-22-2014 | 01:47 AM
Thomas P's Avatar
In my 1/8 MTs Savöx 1256TG
In my 1/10 MT Savöx 1258TG
Thomas P is offline
Old 07-22-2014 | 02:32 AM
xirton's Avatar
My 1/8 truggy: Futaba BLS175SV S.Bus2 HV
My 1/8 Savage: Futaba BLS177SV S.Bus2 HV
Brushless, waterproof and powerful - very happy.
xirton is offline
Old 08-01-2014 | 05:34 PM
chazekxt's Avatar
i use savox 1230
chazekxt is offline
HTML code is On
