Trinity D4 17.5
Old 07-05-2014 | 07:57 PM
  #91
Pittsdriver's Avatar
Originally Posted by elex300
I have a couple pieces of lexan that vary in thickness from .5mm-1mm. When you set the rotor in the rear endbell you will see the gap between the rotor and the 3 hall sensors on the sensor board. I shim the rotor and check the size of the gap with the lexan pieces.
What is the ideal gap?
Pittsdriver is offline
Old 07-05-2014 | 08:36 PM
  #92
elex300's Avatar
Usually between .5mm-.8mm depending on the motor,tolerences in the build,etc. This is why its best to get a inline watt meter so you can do some testing instead of just guessing.
Also I cant stress this enough. If you shim the rotor any closer then .5mm you run the risk of it making contact with the hall sensors. This will destroy the sensor board for sure.
elex300 is offline
Old 07-06-2014 | 10:13 PM
  #93
anybody try the 13mm rotor yet
ashxxx is offline
Old 07-07-2014 | 04:53 AM
  #94
XXXDad's Avatar
Thumbs down Not Legal
Only 12.5 is ROAR Legal
XXXDad is offline
Old 07-08-2014 | 12:41 PM
  #95
elex300's Avatar
There is more then meets the eye with the D4. More info coming soon.
elex300 is offline
Old 07-08-2014 | 12:49 PM
  #96
cobra408 is offline
Old 07-08-2014 | 02:51 PM
  #97
vr6cj's Avatar
Absolutely. I think the Purple rotors are better suited for onroad and the Teal 12.5 is best for offroad imo.
I might have to try this in my onroad then. This D4 isnt faster then my R1 wurks motors in my B5m with the 12.3 rotor that it comes with and I dont want to spend another 40 on it for the 12.5. lol....
vr6cj is offline
Old 07-08-2014 | 02:58 PM
  #98
elex300's Avatar
The purple rotor is 12.3mm and more suited for onroad. Im sure your R1 has a 12.5mm rotor in it which is why you feel it performs better. However I bet if you put the 12.5mm rotor in the D4 you will be very happy. This motor is a torque monster like the D3.5 was but runs way cooler. The difference bewteen 12.3mm and 12.5mm sounds very minuscule but its a huge difference in performance especially in offroad.
elex300 is offline
Old 07-08-2014 | 09:33 PM
  #99
JDM_DOHC_SiR's Avatar
Do tell...
JDM_DOHC_SiR is offline
Old 07-08-2014 | 09:59 PM
  #100
vr6cj's Avatar
Yes, u are right. So I need to spend another 40bucks or 60 for the certified one to make this motor $150-160 stock motor to compete with my others. See where that kinda sucks. No one said this is a cheap hobbie. Ha
ill just run it in my Mi5
vr6cj is offline
Old 07-09-2014 | 12:02 AM
  #101
What does that even mean?
Old 07-09-2014 | 12:05 AM
  #102
Cridd's Avatar
Lol
Cridd is offline
Old 07-09-2014 | 04:57 AM
  #103
I was not to happy with the motor with stock rotor I have rotor coming guess I shouldof got a r1 motor
ashxxx is offline
Old 07-09-2014 | 05:15 AM
  #104
elex300's Avatar
I hate to sound like a broken record but you guys are not comparing apples to apples here. All of the motors you are using for comparison use a 12.5mm rotor. From day 1 I have recomended using the 12.5mm rotor because of its performance advantage. Why do you think a 13mm rotor is not ROAR legal? Anyone who is familiar with the Trinity line of motors knows that they always offer a "Maxzilla" version of every motor and the D4 will be no different. This will include a 12.5mm ht rotor. I know from my testing that the D4 will be the fastest coolest running motor on the track.
elex300 is offline
Old 07-09-2014 | 07:37 AM
  #105
Can you elaborate on this more than meets the eye thing?
