The AE FActory Team B44.2 Thread >
Old 06-29-2014 | 03:51 PM
  #7861
Nat Maniac's Avatar
Can anyone tell me if there is really any difference between a something like a $100 radio and a $550 radio?
e.g Futuba 2pl and 4px
What I mean is how will a more expensive radio help you to become a better driver?
I cant help thinking that there is really only 4 actions forward, backwards, left and right, surely its more about getting used to the radio you have and learning how to manage the tensions within the trigger and wheel?
I mean the difference between a 17.5t and a 6.5t motor is undeniable, all other things being even the 6.5t will beat a 17.5t and just not sure the same holds true for these expensive radios...
Nat Maniac is offline
  #7862
Nat Maniac's Avatar
Old 06-29-2014 | 03:59 PM
  #7863
Jdemonto's Avatar
Big difference features and ergonomics. If you just a basher the. Anything will work. I went from the 3pl to the 4pls and what a difference. It's more comfortable the wheel is more precise. I don't use the advanced features but I do run 3 cars off it.
Jason
Jdemonto is offline
Old 06-29-2014 | 04:05 PM
  #7864
Jason
+1
lee111m is offline
Old 06-29-2014 | 04:07 PM
  #7865
islander360's Avatar
The biggest difference is features, response time and adjustability. The higher end radios will allow an experience user to fine tune steering and throttle curve, EPA, dead band, left or right handed wheel position among other things. There are many reviews on radios, do your research and see what applies to you.
islander360 is offline
Old 06-29-2014 | 06:26 PM
  #7866
Default axle pins
Is there a stronger axle pins then the stock role pins ,like a solid axle pin that fits properly
Airride is offline
Old 06-29-2014 | 07:20 PM
  #7867
Waflet's Avatar
Hideeho
Yes.
http://avidrc.com/product/5/accessor...cessories.html
Waflet is offline
Old 06-29-2014 | 07:48 PM
  #7868
racer_guy's Avatar
not saying a better radio will make you a better driver by any means...but once you reach a certain point, a lower end radio can restrict you to a point because of the "lag" in time. a radio is the most expensive investment you will make. choose wisely.
racer_guy is offline
Old 06-29-2014 | 07:51 PM
  #7869
Jdemonto's Avatar
Originally Posted by Waflet
I tried the 1/16 pins and they just slip out when you take the wheels off.
Jason
Jdemonto is offline
Old 06-29-2014 | 07:57 PM
  #7870
Jdemonto's Avatar
Just finished up the Top Gun Challenge at Sdrc and met Kurt Wenger from Schelle racing. I got a sneak peek at the new shorty pack conversion using the Aluminum chassis. Let's say very dialed!
Jason
Jdemonto is offline
Old 06-30-2014 | 06:04 AM
  #7871
Default spur gear
I'm using the stock spur gear ,is there a stronger spur gear,than stock spur gear ,I'm getting little peoples stuck on it ,is there a steel spur gear available. For the b44.2
Airride is offline
Old 06-30-2014 | 07:16 AM
  #7872
Jdemonto's Avatar
I have been running a Schelle Nova which is little stronger than stock without any wear issues. Is your mesh set properly?
Jason
Jdemonto is offline
Old 06-30-2014 | 07:58 AM
  #7873
Jason
Yes ,my gear mesh is set properly,it's not really stripped ,it's when little stones hits the spur
Airride is offline
Old 06-30-2014 | 08:03 AM
  #7874
fq06's Avatar
I haven't seen a way to enclose the spur gear to keep pebbles out so if you race on a gravely track the best thing you can do is check the spur after every run and kick the pebbles out with a pick or whatever you have. Also a steel pinion... not that it will help the spur but it will last longer than aluminum at an outdoor track.
fq06 is offline
Old 06-30-2014 | 08:07 AM
  #7875
fq06's Avatar
I use the AE pins and they don't fall out and yokomo pins are also supposed to fit. http://www.amain.com/product_info.ph...am-Axle-Pins-4
http://www.amain.com/product_info.ph...heel-Hub-Pin-4
fq06 is offline
