Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 06-13-2014 | 12:15 AM
  #21241
monkeyracing's Avatar
Originally Posted by ruebiracer
Hi Jim,
I´m thinking of getting a V2, too.
Do you know, when stella will restock?
Do they take pre-orders via email?
I´ve not ordered from them by now, I think you know them for a while.
Good luck for your assembly,
Matthias
Hi, I'm not sure if they take pre-orders. You should try. It never hurts to ask. I've been ordering from Stellamodels since 2009. They're one of my favourite suppliers, along with Banzai Hobby, RC Mart and Vellrip. Between this group, you can get almost anything. There is one company I know of that does pre-orders for sure. They're located at 1999.co.jp
monkeyracing is offline
Old 06-13-2014 | 04:56 AM
  #21242
banana rt's Avatar
hey guys, need advice for a must hop ups for making m05 into a great racing machine.
univ shaft
ball diff
alum steering set
alum front rear knuckle
alum motor mount
shock tower
any advice for making it better? or its just enough?
thx
banana rt is offline
Old 06-13-2014 | 07:54 AM
  #21243
Originally Posted by ncpantherfan
I am still running about half a sec behind the fast guy on our out door parking lot track. He is faster on the corners, but I am faster on the straight. We are both using thee same motor, kill shot, same battery, venom, same tires, type a slicks. I am long wheelbase with a 06 cooper body, he is med with the JCW cooper body. I have the complete aluminum steering upgrade, tamiya shocks, m05 ball diff, carbon fiber front shock tower, high torque servo saver, futaba s9551 low profile servo, and full bearings of course. Please take a check my setup and let me know if you see anything that is costing me time in the corners. Track is a good sized, about 110x60 PVC, one long straight and mostly 180 and 90 degree corners, treated with soda\sugar traction compound. The last race I did notice I had quite a bit of chassis lean, I had to trim the front of the body to keep it from rubbing on the track.
Front
Losi 40wt shock oil, 3 piston, mounted to middle hole, floro red springs, 5mm ride height, 2 deg camber with the setting upper arms on the inside top hole, 1 deg toe out.
Rear
40wt shock oil, 3 hole piston, stock rear shock mount, 4.5 ride height, floro red springs, 2 deg camber, 1.5 deg aluminum toe in carrier, upper arms on lower inside hole.
I have a complete set of springs, floor and regular, and white springs that came with my v1 m05 pro, and sway bars. If I need the carbon fiber rear mount I will get it, this is my favorite class to race.
I'd change tires. But then, if they make you faster, he'll change tires and you'll be down 0.5 sec. again. Change to the S-Grips and use the premounts the TCS guys use---#1016. Learn how to doctor the sidewalls with cyano and you should pick up that time easily.
Let me share with you the "worst" kept secret of the good, veteran Mini racers. You can pick up a lot of time with just minor adjustments to your set up. My car of choice is the M03. A 1/4 turn adjustment to the steering rods was worth almost 0.5 sec. I'll bet there's a second left in your car without doing any major changes.
Here's some stuff you can try. It's hard to be specific cause you don't mention if your car is loose or tight, quick steering or slow, stable or responsive, etc. Generally, Minis tend to do better with stiffer springs in back than in front. Try the neon blue springs in the rear. They also like rear roll bars. It's amazing how much time you can pick up with ride height changes, rear camber changes, toe out changes. Sorry, but these are the types of things you have to fiddle with to get the max out of your car.
You've got a decent base setup on your car. It seems that what the car needs is minor set up changes to fit you and the track.
Granpa is offline
Old 06-13-2014 | 08:44 AM
  #21244
univ shaft
ball diff
alum steering set
alum motor mount
shock tower
thx
IMO... Must haves in order of importance are:
Bearings
Alum motor mount w/ the handlebar thingies and a fan
Any short spring set: old or new
Front shock tower
Universals
I didn't mention the ball diff (the diff is the most important) because you can use the gear diff and just fill it half way with putty.
The only important part of the entire steering hop ups for me is the
steering posts #54193 to prevent flexing. the rest of hop up steering stuff is eye candy
Markus is offline
Old 06-13-2014 | 08:58 AM
  #21245
Question on motor fans...
Does Tamiya rules limit you on how you mount your fan? Can't find anything on it.
Carnage9270 is offline
Old 06-13-2014 | 09:59 AM
  #21246
no rules how to mount.
Fan rules are:
number of fans - two total
max size of fans - 30mm by 30mm?
Markus is offline
Old 06-13-2014 | 11:22 AM
  #21247
ncpantherfan's Avatar
It is hard to explain, my car turns on a dime, I like an aggressive steering car. In the corners it seems to loose power on the way out and the rear will step out easily. I think it is something minor, I think I may be over driving, and can't get the power back down after a corner. I do wear front tires on the inside edge very quickly.
I will try the stiffer rear springs and sway bars first on both ends then just rear.
ncpantherfan is offline
Old 06-13-2014 | 11:37 AM
  #21248
try the shock tips from these vids.This guy is an A-main regular and writes columns for Japanese rc magazines.
+ YouTube Video
+ YouTube Video
inpuressa is offline
Old 06-13-2014 | 12:02 PM
  #21249
niznai's Avatar
I think you've got too much camber on the front for how much your car rolls (not enough). The way your front tires wear out suggests you're scrubbing speed in the corners and then you have to accelerate a lot more to get back up to speed. Not knowing what diff and motor setup/timing you run, I can only guess what happens. Maybe you cranked the timing too much for your gearing? Poor acceleration depends on nailing both at the sweet spot. You're faster on the straight because of the high camber and low toe in so you have lower rolling resistance, but in the corners more toe would help you. Increasing the spring rate on the rear and adding rear sway bars will help you, but you already have too little rear grip (you say it is spinning out), or perhaps your strategy is not perfect (it may be lift-off oversteer because you enter the corner too fast and let off mid corner). I prefer to run a higher ground clearance and let the car roll as much as I can especially with minis where adjusting ride height is pain the butt but in your case I would drop the rear another .5mm too.
Your longer wheelbase is not to your advantage either.
niznai is offline
Old 06-13-2014 | 12:17 PM
  #21250
Your car is probably diving too much into the turn. The excessive roll will cause the car to hook. That's where the two orings in the diaphragm (in the vid) comes in to play. It will allow the car to roll to a certain point and stiffen up a bit to keep the car stable. The general setup is to use a harder spring in the back. Maybe you can start by changing the red floro to something stiffer like yellow front, blue rear.
btw, have you built the ball diff with anti-wear grease?
Old 06-13-2014 | 02:51 PM
  #21251
EricP's Avatar
Default M05v.2
Done! A few finished product pics for you guys.
yea yea yea.... needs a sensor wire....
Special thanks to Robert @ KO Propo USA for re-wiring my BLZ speed controller, as well as providing a low-pro servo for this build.
EricP is offline
Old 06-13-2014 | 02:56 PM
  #21252
Originally Posted by EricP
Done. A few finished product pics for you guys.
Nice how the shorty allows you to have a bigger window to balance L/R
Old 06-13-2014 | 03:34 PM
  #21253
Default M03 or M05?
I just finished building an m05 (not pro), 100% stock except bearings and oil shocks. Then I got a great deal on 2 m03s. One is a shiny silver chassis with bearings and aluminum front/rear knuckles. Which should I go with and tune up for the track? Its concrete, new and kinda dusty so fairly low traction.
sad_rocc is offline
Old 06-13-2014 | 03:41 PM
  #21254
Very nice! What option parts did you use there EricP?
Old 06-13-2014 | 03:49 PM
  #21255
Please, the following is just my opinion and could be way off. From your description, you have too much initial steering on turn in and you're scrubbing speed mid corner. Usually this is a symptom of the car setting too quickly. You can counteract this in any number of ways, some more effective than others and can vary wildly from track to track and car to car. Stiffer rear springs, rear roll bar, heavier shock oil, sometimes a softer spring in front, raising the front ride height or lowering the rear, add a little more toe out are some things just off the top of my head. Oh yeah, a little tighter diff can sometimes help. Try them one at a time and see if they help.
Your car is skidding the front tires so you have to wait to get on the power. All minis in my experience push under power, but if your car is already scrubbing the tires the push will be exaggerated. when you apply power. You're wearing the front tires excessively cause your running your tires at a high slip angle in the corners. The slip angle being the amount the tires are angled to the direction of travel.
Some of the rear end problems you're having are the result of the front end, cause it's over powering the rear. In effect your car isn't balanced. The things you can do to the rear to help with the looseness are: replacing the 1.5 rear hubs with the stock 2.0 hubs, drop the rear ride height, add camber like 2.5 instead of 2.0, stiffer spring, softer spring, softer shock oil.
You can also do a lot with Tx adjustments. On a car like yours, I'd slow down the servo speed and cut down on the travel.
That's the simple stuff. The rest is in how you build the shocks and the diff.
Granpa is offline
