Futaba T4PX
Old 05-16-2014 | 09:00 PM
Default Futaba T4PX
For the people that like telemetry, this seems like an awesome solution! If this is as good as it looks, there isn't anything else on the market currently that can touch it.
http://www.minicars.se/2014/05/futaba-t4px.html
Pre-Release specs:
Features:
– Completely new design
– Low steering position for a low centre of gravity
– 15g lighter than 4PKS-R
– All in one transmitter antenna
– 2.4GHz system – T-FHSS, S-FHSS & FASST-C2
– The Following receivers can be used with 4PX: R304SB, R304SB-E, R614FS, R614FF-E, R2104GF, R204GF-E & R203GF
– QVGA3.5 inch TFT colour LCD screen with perfect visibility under sunshine
– Sensor slot function (telemetry channel)
– Up to 31 sensors can be utilised
– Equipped with telemetry voice output
– Mixing function : 5 program mixing. 4WS mixing & Dual ESC mixing
– 40 model memory
– Left handed supported
– APA handle extension supported
– 25mm extension adapter
– Push type button power switch
– Auto-power off function
– Vibration motor
– Earphone jack
– New high-durability stick potentiometers
– Communication port (For setting ESC, servos, sensors)
– Micro SD card slot (SDHC)
– Updateable software
– High-point detectable throttle trigger
– Throttle trigger movable by 7mm
– Throttle trigger shape is optimised as well as stiffness is increased
– Combination steering rubber
– Steering angle can be selected (32 degree and 43 degree)
– Telemetry “disabled” LED
– Two different types of throttle triggers are included (can be easily changed by a screw)
ufoDziner is offline
Old 05-17-2014 | 01:48 AM
...and 30% faster than the 4PKSR. Wow that is a big leap. Futaba should post the actual latency time. 30% faster than the 4PKSR which was 5% faster than the 4PKS is pretty vague. The 4PKSR is no slouch. Not as fast as the M12, but still fast.
My ST-RR EVO is offline
Old 05-17-2014 | 09:43 AM
It appears that this is the same radio that has a thread already going for the last couple weeks. Seems best to keep it all together there for everyone's benefit.
If I am in error please advise, if not I will close this thread. And perhaps I can ask the other thread starter to update his first post with the specs.
http://www.rctech.net/forum/radio-el...utaba-4px.html
Dave H is offline
Old 05-17-2014 | 06:10 PM
Looks the same to me. I searched for T4PX and T-4PX before starting this one. It would be great if the radio had a consistent name (shows T4PX on the screen in the videos and 4PX on other sites). *shrug* Thanks.
Old 05-17-2014 | 09:49 PM
DanielC.'s Avatar
FWIW, the 3PK and 4PK are technically the T3PK and T4PK, respectively. Look at either of them closely and you will see the T prefix on there.
DanielC. is offline
Old 05-17-2014 | 10:33 PM
choisan's Avatar
Done!
Spec updated with photo added.
choisan is offline
Old 05-18-2014 | 05:39 AM
Originally Posted by choisan
Done!
Thanks guys. Good luck with your new toy.
Dave H is offline
