SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 04-29-2014 | 02:56 PM
  #3256
Originally Posted by kahuna2793
What kind or run time you get?
I put about 2800 mAh back into it after a 10 min main with a few min warm up. The one time I ran to LVC, I think I was on the track around 18 min or so, but you have to take into consideration that's 18 min of practice, not racing. Practice will yield longer run times because you sometimes have to check up for wrecks or just avoid other cars because there are too many out there.
I run a 2100kv motor and I'm pretty easy on the trigger. This was on 2 medium - large tracks (~200 foot straights)
Bob Barry is offline
Old 04-29-2014 | 04:47 PM
  #3257
Would the 4s 5000 may 50c factory spec be ok to run in my 1/8 e buggy?
Dagolf is offline
Old 04-29-2014 | 05:08 PM
  #3258
ThePanda's Avatar
it should work just fine.
ThePanda is offline
Old 04-29-2014 | 05:15 PM
  #3259
Good deal. Thanks panda! Can't wait to get this thing...I've had my 3.0 e built for a week and I hate that it hasn't gotten to check out the track haha
Dagolf is offline
Old 04-29-2014 | 05:30 PM
  #3260
Was thinking about spending the extra $20 for the 6500 but think I'll go with the 5000 for my MBX6 Eco. Might as well go all out budget build lol
iTz Nicholas72 is offline
Old 04-29-2014 | 06:03 PM
  #3261
Ya I didn't really budget this one haha 1/8 scale gets expensive quick
Dagolf is offline
Old 04-29-2014 | 06:30 PM
  #3262
Anyone know the difference in run time 4s 5000 vs 6500 smc in 1/8 buggy?
kahuna2793 is offline
Old 05-02-2014 | 11:04 AM
  #3263
30% more capacity should yield 30% more run time
Mudblaster is offline
Old 05-02-2014 | 11:31 AM
  #3264
ironzgti35's Avatar
I have yet to run a track that I couldn't get a 10 min main out of my 5000 packs. As far a racing goes the 6500 is just overkill and extra weight to carry around
ironzgti35 is offline
Old 05-02-2014 | 02:32 PM
  #3265
So I just got my SMC 7200 2S batteries...I went to solder on my usual "banana" connectors, but promptly found that the wire insulation is too big to fit through the plastic "polarity protector" case thing. I tried to force it by a few different methods...nothing seems to work.
These are the type of connector: http://www.amazon.com/Redcat-Racing-.../dp/B00D25G2HA
It goes like this--to attach these, you slide the plastic cover over the wire, solder the bullet, and pop the plastic cover over the bullet. But if you can't slide the plastic over the wire in the first place, there is no way to get it on the bullets after soldering the bullets on.
So what do I do? Do I just switch everything over to Deans' connectors? I don't want to use bare bullets, plus I can't...I didn't order that version of the battery. I want to keep all my batteries "universal" so I can charge them all the same and put them in any vehicle, but the only batteries that are giving me this problem are the 6 new SMC batteries.
Is there a connector other than deans that would be good? This will be used on everything, SC, 1/8 truggy...
What would y'all do, other than start with the batteries with 4mm bullet sockets built in? (Them just look like a problem waiting to happen to me, but to each his own?
fredygump is offline
Old 05-02-2014 | 02:38 PM
  #3266
SMC has "EC5" and "XT60" connectors. Any experience with those? They look fine, and don't slip over the battery wire, avoiding my problem...
Old 05-02-2014 | 03:02 PM
  #3267
DRTMI's Avatar
Super Moderator
Both are good connectors. The EC-5 are 5mm, I believe, and the XT-60's are 3.5mm. I have used the XT-60's and they are a good plug. No experience with the EC-5.
DRTMI is offline
Old 05-02-2014 | 03:05 PM
  #3268
I have soldered both of those connectors before and they worked fine. Guessing the batteries you got have 10ga wire and that is why they wouldnt fit your other connectors.
Zonk is offline
Old 05-02-2014 | 05:51 PM
  #3269
Hoese37's Avatar
Just go with deans. Those connectors you have now are known to be pretty awful.
Hoese37 is offline
Old 05-03-2014 | 07:00 PM
  #3270
I ended up with the xt60 connectors. they look good, well made...fit snug. the guy at the hobby shop sounded like he was scared of soldering dean's connectors.
Ran the smc batteries today. They have a huge amount of punch. I couldn't ask for a better battery!
