Like Tree12Likes
Tekno NB48
Old 03-28-2014 | 06:43 AM
  #1066
Bortzilla's Avatar
She's so beautiful...
Question - What flywheel wrench are people using with the Tekno flywheel/clutch?
Bortzilla is offline
Old 03-28-2014 | 08:56 AM
  #1067
Hoese37's Avatar
I don't use one. get a good channel lock pliers.
Hoese37 is offline
Old 03-28-2014 | 08:59 AM
  #1068
YANMAN's Avatar
This is the only tool I have found for a 4 shoe clutch. I am not sure it works on the Tekno clutch.
http://rcrenew.com/tools.html
I just use channel lock pliers on the 4 shoes. Your flywheel will have marks on it after you run a few times anyway.
YANMAN is offline
Old 03-28-2014 | 05:40 PM
  #1069
FastPete's Avatar
That is sweet nice ride!
FastPete is offline
Old 03-28-2014 | 06:03 PM
  #1070
yeah nice looking machine you got there mate
RavensNightFury is offline
Old 03-30-2014 | 03:23 AM
  #1071
vandalzzz's Avatar
I've almost finished my build (2 bags left), but i've moet some issue: ProTek starter box' rubber wheel can't reach flywheel with brackets on (but can w/o brackets). Here is fullsize pic, gap is clearly visible (it's about 2-3mm). I've already written to Amain support, but decided to ask here, maybe i'm missing something and doing some things wrong? Clutch system is stock one.
vandalzzz is offline
Old 03-30-2014 | 04:31 AM
  #1072
BigInJapan's Avatar
Nah ur not missing anything, the engine sits forward and central more than most other buggies. I made some customs stops for my hudy starter box.
BigInJapan is offline
Old 03-30-2014 | 05:41 PM
  #1073
vandalzzz's Avatar
But my problem is not about limited variations of pins&brackets, i am able to set up those things right enough to locate chassis in proper position.
Finally i've removed only rear bracket and was able to touch wheel by wheel pressing hard enough to develop chassis flex. Maybe i need to press some more to make things work with both brackets? How hard it meant to be pressed in 'normal' conditions?
Old 03-30-2014 | 09:03 PM
  #1074
BigInJapan's Avatar
I see what you are saying now, I don't have that problem on the hudy box because the locating pins sit straight on the top of the starter box case, as does the chassis of the buggy, there's no 'brackets' also sitting under the chassis.
It's always best to push down on the engine to reach the starter wheel, but I don't have to flex the chassis at all to reach it, normally. Maybe those who use the Ofna box can help you out more, as they also have the sliding brackets.
Old 03-30-2014 | 11:42 PM
  #1075
JsK's Avatar
JsK
Lets get this figured out so you can go burn some nitro
Here is my car on the OFNA box. Notice you can only see one side of the wheel
due to wear.
Here is the box without the car. Again notice the wear on the wheel. It still
reaches the flywheel like this.
Here is one with the box in the down position.
And here are a couple of the flywheel.
JsK is offline
Old 03-31-2014 | 12:51 AM
  #1076
vandalzzz's Avatar
due to wear.
Thanks for pics. It's not so obvious on that photos: does your wheels hit each other only with top plate on st.box in lower position without flex in chassis? Or you need to push hard not only to engage st.box but to reach rubber wheel with flywheel making chassis flex?
Old 03-31-2014 | 03:51 AM
  #1077
vandalzzz's Avatar
So i've measured everything involved:
- Clearance between chassis line and flywheel: 3.2mm
- Highest point of rubber wheel (from top plate' line): 5.5mm
- Thickness of the bracket: 5mm
Basic math tells that there is more than 2.5mm gap between wheels.
Old 03-31-2014 | 04:24 AM
  #1078
JsK's Avatar
JsK
No you should not have to push down that hard. My guess is that your not
centered above the wheel. Pull the motor. Mark the wheel on the starter box
and then turn the wheel until the mark is at the very top. That mark should
be right in the center of the flywheel hole in the chassis. Move the pegs until
the starter box wheel is not only centered front to rear but also left to right.
Notice how the car is not centered on the box.
I you have the wheel right dead center in the flywheel hole and it still wont
reach your flywheel you can try a couple of things.
First look inside and make sure nothing is caught in the spring/switch
assembly keeping it from collapsing all the way. If thats all good and you
have the lid compressing as far as possible the next step would be to try
shimming the motor plate up , between the bottom of the box and motor
bracket. A couple millimeters is all you should need.
JsK is offline
Old 03-31-2014 | 05:56 AM
  #1079
JsK's Avatar
JsK
HMM mine comes up about 8.5mm at full compression. I would give Amain a call
and see if they have any ideas. Or you can shim it up.
JsK is offline
Old 03-31-2014 | 06:52 AM
  #1080
vandalzzz's Avatar
I've already written to their support, let's see how they can handle this issue. My previous experience with their customer support center was very good, hope they gonna handle current case well, esp. with fact that ProTek RC is their own brand.
Anyway i don't think that total uptravel of their starter box (5.5 - 5.0 = 0.5mm) is acceptable for nitro cars. There is no shims in kit, but desc. stated about '95% ready - fit brackets and go'. Seems i've got sort of PITA...
