Tekno SCT410 Thread
This until proven otherwise is a bad solder joint, bad plug, or a bad switch, I've seen this a lot in planes if the ESC is resetting its one of the three.
Resolder everything, "change your plugs", probably not the switch but could be, if you still think its the switch remove it and solder the wires together, and see if that does it.
If after that your still having issues I'm betting there is a bad solder joint inside the ESC. You might have gotten the lugs too hot and messed up a joint inside.
Hope this helps
Randy
Hope this helps
Randy
changed your plugs! Drive on!
If the deans plug is not loose on the contacts it won't cause a issue . Just set the cutoff at 3.0v or you have a bad solder joint somewhere .
Kslimm: I would race it at SJ a few times to get used to it with the ground so wet outdoors don't think it will be dry intill April.
All of the motor mounts have 2 screw hole/slots for attaching the motor mount insert, one on the top and one on the bottom. The older versions of 5210 and 5210x had an open ended bottom screw slot to allow the bottom screw to just be loosened to pull the motor whereas the newer, updated versions have a closed off slot where you'll need to completely remove the bottom screw to pull the motor.
Here's a pic of the newer style bottom slot-
Hope this helps
Randy
Hope this helps
Randy
What I didn't try, and I wish I would have. I didn't think of it at the time. Since I have 2 batteries. As soon as the issue started, I should swapped in the other pack quickly and went back on the track. That way I would know for sure if it's a battery issue. If it would go another 5 min or so until it starts acting up it's obviously the battery voltage. If it continued to shut down then it is most likely a heat issue somewhere. Most likely inside the ESC. Probably once it gets warm maybe there's a poor solder spot on the circuit board or something. Ill try this as well on Wednesday when I'm back at the track.
So im rebuilding my truck today and quite surprised by more than a few things. First off a lil truck history. I bought this truck used from a buddy back in early August of last yr. He had bought it used from a guy that said he only ran it once. Anyhow, it had approximatley 9 race days on it by the time I purchased. I only ran it 5-6 times up until I found my way onto the Team. This truck has been raced twice a week ( missing only 3 Wednesdays) since October. I am now replacing a couple of bearings and the CVD's simple because I feel guilty. Ya, ive replaced the center and rear drive pins before but I honestly now have a bag full of GOOD USED PARTS.. This is seriously amazing to me because when I ran the losi truck it was a ritual once a month thing to buy and replace all CVDs and usally a bearing or 2 along with some warped arms and not to mention the countless shock seals.
So basically I am only reiterating what most already know, but its nice to see the quality that TEKNO RC has put into the products we race.
Thanks again TEKNO RC for your fantastic product.
thanks for the reply. i guess i was getting confused because of the mention of a 1 screw only setup. that doesnt exist right? also , does the sct410 with the closed ended slot have the brake mounts from the buggy on it or is there an specific updated sct mount? im asking because one way or another im 99% sure im ordering a new mount to either freshen it up or get an updated one because the one i have now lets the motor rock to much when trying to set mesh. just want to be certain im getting the correct parts .
Hey guys I have a problem with my gen 2. I posted this same thing in the RX8 thread but figured id do it here too since a lot of you guys run similar set up. It's brand new. Hooked up to a HD4300 motor in my tekno sct 410. I'm using brand new Smc 5000mah batteries. I get about 5 min run time until the ESC will shut down and restart every 30 seconds. I'll have no power, only steering. Once the ESC resets the truck will run just fine again for about 30 seconds and it will cut power and restart again. I know this because one of the guys was standing by the corner of the track when it happens and he hears the ESC restarting. Any ideas why this is happening? I check my batteries right after this happens and they are around 3.8v per cell still.
This is a small running change on newer SCT and EB kits. If you want to guarantee that you get a closed slot mount, order TKR5210 from www.teknorc.com. The parts are filtering through the channels.
I would definitely pick up the updated part if it would get rid of the slop and hold the motor straight without relying on the fasteners... like little to no lateral motor movement.
I don't say this as a dig on your part but if you want I can send the Elite RC mount from my Mugen SCT for you guys to look at. That is by far the best motor mount I have used. Completely locked in without any tension on the screw (1 screw). And has never budged from its setting even with only one screw to fasten it.
The Mugen has been in the shelf since I got this kit
And there is no one screw only motor mount.
My 410 was a first batch rig, I've been bragging that mine have been run every single weekend for over a year without a single part failure. I always take my highly upgraded scte with me to the track in case my 410 breaks. Well it finally happened big time. I was racing on a real nice med size indoor track and got bumped coming off of a small jump at good speed and hit one of the steel poles that help support the building. You hear that loud bing every once in a while. After hitting the pole hard I was able to finish the race but my 410 wasn't handling correctly but I did finish. I broke the aluminum front suspension pin holder in half, the pin tore almost all of the way out of the arm. Any way after a whole year of racing and tons of practice laps I finally had to spend a few bucks. The funny part when I first purchased the 410 kit I started buying spare parts. I have almost every thing other than a set of front arms, I have a set but turns out they're for me eb. Bottom line after one year of hard practice and racing I finally broke less than $50 worth of parts. Not bad I'd say. If I hadn't got bumped into a BIG steel pole I'd still be running my stock kit. LOL I've been so happy since I switched from Caster to Tekno. I never finished an A main with my Caster rigs, always finish with Tekno. With that said, Tekno get busy I have all your E rigs you need to build a 1/10 4x4 mod buggy to compete with the new Hot Bodies buggy. Should bring the class back to life. I can't afford to rebuild my Kyosho every month.....
2 things, they can brown out and still have a servo work, I had it happen. But I think it may be a battery issue also. Gotta remember that a 50c 5000 battery does NOT deliver the same as 50c 7200 pack as its all relative to overall battery power. I personally would do both. get a glitch buster and a better/bigger battery. Any chance you could borrow a better battery from another racer to test?
17Likes
