Like Tree2Likes
RB Concept Engine Thread..
Old 02-04-2014 | 09:52 PM
  #3376
It has the oomph but I think I could use more bottom end. I've ran it with the 9886 so it could be the reason. I will try another pipe later when I have the chance.
A7racer is offline
  #3377
Originally Posted by A7racer
after seeing a couple of my buddies snap a rod in the last month in their engines....other brands, I don't want to risk losing the whole engine with a damaged sleeve
other brand rods break because they aren't tempered good like Nova and OS, and not the same quality.. and Nova make RB so.. I wouldn't worry..
Eivind E is offline
Old 02-04-2014 | 09:54 PM
  #3378
As a matter of fact, I just remembered. One guy did indeed lose a rod on an RB C6 about a month ago
A7racer is offline
Old 02-04-2014 | 10:57 PM
  #3379
Use a novarossi R7 rod,The Rb rod is a 5.02mm crank pin and will not fit.
kyosho28 is offline
Old 02-07-2014 | 08:46 AM
  #3380
Man I'm really tempted by that RB Rally engine to put in my buggy for shxxs and giggles.. Just got some Amain discount codes too. At minimum I'd get 12 bucks off - it'd be like $178... I guess if it's a rally eninge it's designed to rev high, with not so much torque, so I assume something like a 2013 torquey pipe would be good for it......
Herrsavage is offline
Old 02-07-2014 | 09:59 AM
  #3381
Maximo's Avatar
that engine is likely the same as a Fire 11........The Fire 11 was just a offroad dressed Rally 11....
Maximo is offline
Old 02-07-2014 | 10:23 AM
  #3382
BillyT.'s Avatar
V19 has Nova crank and nova rod with smaller pin. At least mine does.
And on road motors traditionally have way more torque than off road motor, as the cars have the potential to generate a lot more grip and actually use the power.
I have a friend that runs a Speed in his buggy and it's pretty nuts.
Kinda wish I had gotten the Rally instead of the V19 as it's gonna most likley end up in my truck.
BillyT. is offline
Old 02-07-2014 | 11:21 AM
  #3383
If it's a F11, it at least doesn't have the good front bearing... However much a difference that makes..
The Rally also says 14.5mm crank, the Fire 11 14mm....
Old 02-07-2014 | 09:51 PM
  #3384
BillyT, you don't like the V19? Not enough for truggy? You had the V11 right, and loved it?
Old 02-10-2014 | 09:31 AM
  #3385
BillyT.'s Avatar
V11 in my truck was cut. Been running it with 6.5 nitromizer insert in buggy to slow it down.
Verdict still out on V19. Just haven't had enough time to run it...
BillyT. is offline
Old 02-16-2014 | 06:06 AM
  #3386
Just got three tanks through that used Fire 11 I got (and had pinched..) Ran great.. The 2045 (with different, longer header) was kind of lame. Put on an SH "High Torque" pipe, and it was much better. No EFRA number, so not raceable I guess.. Need to get me a 2013 pipe...
Old 02-16-2014 | 06:22 AM
  #3387
aznitronut's Avatar
Try the 2058 pipe on the F11, I ran it on mine, I got over 10 minutes on a tank, using it in the new Losi T 3.0 truggy.
aznitronut is offline
Old 02-16-2014 | 06:28 AM
  #3388
I have a 2058 on my other Fire 11 in my RC8T for racing - love it.. For bashing around in the SC8 though I want something with more top end.. The 2058 is great on a track, but it's not quite the top-end screamer I want this other F11 to be.. Though yeah, I probably ought to have something with an EFRA number on it, in case I need to throw it in my buggy or truggy at some point..
Old 02-16-2014 | 06:35 AM
  #3389
aznitronut's Avatar
Try a shorter header on your 2058 on the F11, that should give it a little more top end. I don't think the 2013 will do As good as the 2058, have you tried the 2086? That's more of a top end pipe.
Old 02-16-2014 | 06:40 AM
  #3390
I have an Ofna 086 on a Nosram/Picco.. Might try that. Like this SH pipe so far though..
