Go Back  R/C Tech Forums > General Forums > Rookie Zone
Car doesn't work when on the ground >
Old 01-09-2014 | 11:45 AM
  #16
CookieFlow's Avatar
Well after 1 hour 30, the car is reassembled and it was indeed the problem !
Ps : The left wheel doesn't turn at the same speed as the right wheel when dragging it on the rear wheels or moving the spur gear manually.
Is it something I should be concerned about?
Thanks you so much for the help guys !
CookieFlow is offline
Old 01-09-2014 | 12:01 PM
  #17
WonTonsChicken's Avatar
Im curious how you got it together backward... Everything lined up nicely?
WonTonsChicken is offline
Old 01-09-2014 | 12:07 PM
  #18
CookieFlow's Avatar
Yes everything worked fine when pressing the trigger and the pieces lined up, I guess it's pretty easy to mess up if you don't know.
Old 01-09-2014 | 12:14 PM
  #19
orangutanracer's Avatar
It should turn the same speed as the other wheels. Maybe you got a bad bearing or something binding that left wheel.
orangutanracer is offline
Old 01-09-2014 | 01:03 PM
  #20
CookieFlow's Avatar
I will look into that !!
Thanks again
Old 01-09-2014 | 01:14 PM
  #21
ThePanda's Avatar
traxxas bearing rust out and bind up easy.
ThePanda is offline
Old 01-09-2014 | 03:23 PM
  #22
CookieFlow's Avatar
noted !! thanks !!
Old 01-09-2014 | 08:34 PM
  #23
RCNYWOLFTEAM's Avatar
Try Checking Your Slipper Clutch It Might Be To Lose
RCNYWOLFTEAM is offline
