The AE FActory Team B44.2 Thread
#6616
Hello, need some help on my B44.2. Just change the stock steering rack to jc aluminum steering bellcrank assembly. Found out that its quite different feel when driving the car. Seems that the stock feels more "relax" when driving it but i have read that the jc ones are better. So which location on the jc one is the same as the stock setting? Also between all 3 position which is the best to use? Thanks in advance. Cheers...
#6617
With the 44.2 most of us seem to have migrated to the forward hole on the 44.2 rack (middle on JC rack) to get a bit more steering response out of the longer chassis. The JC rack adds more response as it has less flex. I would suggest starting with the middle hole on the rack.
Ray
#6618
My experience is further forward is less aggressive and further back is more aggressive turn in. Looked it up to make sure my thinking is correct... its early
From the X-Ray guide:
STEERING ROD INNER MOUNTING
POSITION
CHARACTERISTICS
Forward holes (sharper angle)
• Smoothens out steering response
• Car reacts smoothly
• Better suited to smooth fl owing tracks with
high speed corners
Rearward holes (shallower angle)
• Quickens initial steering response
• Car reacts faster to steering input
• Better suited to small, tight tracks
POSITION
CHARACTERISTICS
high speed corners
#6619
The 2 rearmost holes are the same as stock.. The forward hole is an additional position.
Ray
Ray
#6620
POSITION
CHARACTERISTICS
high speed corners
POSITION
CHARACTERISTICS
high speed corners
#6621
Your end points should always be adjusted to achieve maximum mechanical steering "throw" . Adjust them out until the steering physically stops moving on the spindles. Going too far on the EPA will strain the servo and not enough won't achieve full steering
#6622
Is using a tekin gen 2 4.5 with a tekin RS pro and team powers 5400 35C saddle pack overkill?
I'm currently running 81 spur 16 pinion and my battery is running out of juice prior to the end of a 5 minute qualifier. My ESC and attached capacitor seem to be running hot as well. I'm not sure if the batteries are bad or the motor is just too much.
I'm going to try and get a 6.5 but if the motor is not the problem then I need to find out my next step.
I'm kind of new to electric off road. I mainly run Nitro TC and have very little experience running anything electric.
#6624
I am running a 6.5 with 20t and it is perfect. I run a 6 minute qualifier no problem and I can run around 12 minutes total before the battery dumps.
Dump the motor, go to a 7.5 or 6.5, gear up a tooth or two depending on how large your track is and go from there.
#6625
Your motor is way too much. 6.5 is plenty. You can also benefit from a better battery pack, something with a higher C rating. I ran an RS Gen 2 in my 4wd and while it was fine, it tends to run hotter than something with a fan.
#6626
#6628
#6629
Speaking of my buggy...its for sale as well as a second spare and huge parts lot
http://www.rctech.net/forum/r-c-item...fs-spares.html
#6630
Dude, that blows. I have only broken 1 arm on my buggy and none in the last 3 months of racing since doing the o-ring mod. Sorry you were having bad luck out there.
