Radio Control Hobbies & Raceway - Waterbury, CT.
It made me feel good that the current reigning world champion is/was also confused about roll centers and how to adjust them.
http://jtprc.com/2013/12/29/setup-tip-roll-center/
In a nutshell:
Lowering the inner link = less roll
Raising the inner link = more roll
Lowering the outer link = more roll
Raising the outer link = less roll
A lower “roll center” rolls more
A higher “roll center” rolls less
In a nutshell:
In a nutshell:
In a nutshell:
I'm going to say that more roll/less roll is misleading. You're actually talking about roll center and raising or lowering it. When you lower roll center it allows more weight to transfer and opposite for raising it. Effects vary depending on front rear and of course angle and length of the camber link.
I still like the hudy book for this stuff
http://www.teamxray.com/teamxray/sho...p?file_id=4461
After watching Tebo's post-worlds interview, it was abundantly clear to me that he is not a very smart person...
Tony is correct about roll center. Lowering the inner link and/or raising the outer link actually gives you **more** roll (lower roll center), as the center of gravity is travling along a larger arc during lateral weight transfer. This gives more mid-corner grip at the expense of steering responsiveness.
I took a look at the Hudy setup guide that John printed out. Overall it's not bad, but I found a few errors or at least points of contention, as well as some things being left out (e.g., spindle carrier position). I prefer to rely on my understanding of physics and geometry.
Another resource I use is the following: http://jq-products.com/the-news/43-t.../160-the-guide
Not as user-friendly as the hudy guide, but it provides some more detail for certain sections (i.e. check out the roll center/camber link section).
I also have the ae tuning guide app. Most of it is real basic, and only some of it's useful, but it gives some basic info.
Phu, the roll center is the virtual "center" around which the chassis rolls. In other words, it is a virtual axis of rotation. If you take the camber links and extend a virtual line from them from both the left and right sides, the point of intersection plays a role in determining this axis of rotation. As the inner ball stud drops, this intersection point drops, and therefore the roll center drops.
21Likes
Thanks, I guess I will have to find something else to do....
