The AE FActory Team B44.2 Thread >
Old 12-18-2013 | 08:58 PM
  #6541
gticlay's Avatar
suppose or rather suggested to trim the weight down to 40 grams on the 44.2.
The 44.1 uses all of the ballast.
Its a real pain to cut the ballast.
The weight is made of very hard metal ,even with a hack saw takes real elbow grease to cut..
That's about where I ended up on my 44.2 but I used the 7g wheel weights from the local parts store that are way cheaper than the ballast weight and lets you add and remove weight when you want to (and easily)
gticlay is offline
Old 12-19-2013 | 06:48 AM
  #6542
Wildcat1971's Avatar
Tech Prophet
Is anyone running the 13mm mod rotor in the reedy mach2's? I am running an 8.5 and it seems to run fine, but I was wondering if the 13mm rotor might be a little better.
Wildcat1971 is offline
Old 12-19-2013 | 06:58 AM
  #6543
Autocratic's Avatar
In general, going bigger on the rotor will make more torque, and make the powerband smaller. You'll also run hotter as there is less air gap between the stator and the rotor.
Autocratic is offline
Old 12-20-2013 | 08:47 PM
  #6544
dlncooke's Avatar
Smile B44 switch mounting
Hi, just looking for a good position to mount esc on/off switch on a B44.
any pics would be great.
cheers
dlncooke is offline
Old 12-20-2013 | 09:27 PM
  #6545
TomErickson's Avatar
cheers
I mounted mine on the servo at a 45deg angle. Helps avoid switch off from impacts.
TomErickson is offline
Old 12-21-2013 | 12:15 AM
  #6546
If you're running Tekin, just cut the switch and solder the two wires together.
NitroOB4You is offline
Old 12-21-2013 | 06:40 AM
  #6547
Tech Prophet
I ran the car for the last time at our indoor track last night. the car felt good and was fun to drive, but I lost 2 ball cups and an arm in practice. wheeler is a novelty class here, so I will probably get the rpm arms when they come out. I am driving the car at like 80% effort so I dont break.
Old 12-21-2013 | 04:56 PM
  #6548
Potoczak's Avatar
So who do I need to get a hold of to get the gear diff conversion for the 44.2??
Potoczak is offline
Old 12-21-2013 | 05:19 PM
  #6549
Over 160$ for both diffs.
xTotalghost is offline
Old 12-21-2013 | 05:53 PM
  #6550
Tech Prophet
I will wait and see if AE makes some
Old 12-21-2013 | 08:22 PM
  #6551
mschumi101's Avatar
Bugle Boy racing. I know there have been some problems with parts availability recently, but i know he makes them to order. So just place an order and he will make them.
mschumi101 is offline
Old 12-22-2013 | 05:06 AM
  #6552
Taffyjnr5's Avatar
Hi,
What is a good starting point with oils with gear diffs for the B44.2 the track is hard packed but not blue groove......
Taffyjnr5 is offline
Old 12-22-2013 | 07:36 AM
  #6553
gticlay's Avatar
Had a great day yesterday with my 44.2. I've decided the car is a pusher on power and an over-steerer off power and part throttle driving is just how it's made to work. So much fun to race! It is frustrating that AE still hasn't gone all metric yet. Pretty please?
gticlay is offline
Old 12-22-2013 | 08:22 AM
  #6554
Tech Prophet
yeah, it drives a ot like my t4 with the massive off power and push one power. but more like a buggy and less like a truck. I am really liking it.
Old 12-22-2013 | 01:46 PM
  #6555
I ran my first race with my new (used) B44.2 yesterday. Wow what a car! I started with a set-up sheet from AE and adapted from there. In practice I tuned in the slipper and removed the 80g ballast weight. Once I did that this car was on fire. I was running a Novak Pulse with a 7.5t motor and it was plenty of power for the car. My Panther Rattler Clay rear tires and Proline scrubs worked well on the medium grip tight clay track. I qualified 3rd against some top competition and was running 4th in the main when I made a mistake over a jump and rolled it causing the rear half shaft to pop out. I need to either shim the shaft or limit the droop now.
Love the car!!
