Like Tree1Likes
Sirio engines thread
Old 11-25-2013 | 02:50 PM
  #2821
Anyone besides me still running Sirio off road engines? My Kanai Evo3 STI is ballistic,seemed to drink less fuel than people said but I have no numbers regarding runtime.
30Tooth is offline
Old 12-18-2013 | 08:23 AM
  #2822
Does anybody know where I can find Sirio .09 engines for a mini inferno 09? Or better yet, an engine thats about the same size with rear exhaust.
vines is offline
Old 12-18-2013 | 08:27 AM
  #2823
Another Sirio question: is the silver-head .24 a turd or what? My Orion .24 was...
Herrsavage is offline
Old 12-19-2013 | 03:00 AM
  #2824
Default Sirio CL7B + Sirio 2021 pipe
Hi guys
I never had a sirio engine before so I was wondering what do you think about this engine and pipe?
How are sirio in terms of tuning, reliability and fuel consumption?
I found a pretty good deal in Italy
Any info welcome
Thanks a lot
Frans1978 is offline
Old 04-29-2014 | 10:58 AM
  #2825
Hi: All
Just wondering what you guys think of this motor the "Sirio SM Pro .21 1/8 On-road"
is it a goodin and where(if) can l get parts for it.
l can get a just broken in one on ebay for $200 just replaced con-rod and bearings.
Love to know what you guys think
Tracker Ryan is offline
Old 08-10-2018 | 05:34 AM
  #2826
Has a new Sirio engine, S21 BK EVO2 but no crankshaft, are they able to get somewhere?
roddy123 is offline
Old 08-12-2018 | 05:28 AM
  #2827
Sirio went bankrupt a few years back.
The engine I would have liked to have sampled from Sirio was the Sirio CL7B STI.
Pedro Jesus is offline
Old 08-12-2018 | 08:21 AM
  #2828
have you ran this engine, I got one last year that was just broken in and not really ran it's still tight. I gotta see what pipe is good with it. Is this engine like a werks b2? Weren't they made in same factory not sure if they are different.
jersey is offline
Old 08-13-2018 | 09:17 AM
  #2829
[QUOTE = jersey; 15278094]
você já correu este motor, eu tenho um ano passado que foi apenas quebrado e não correu ainda é apertado. Eu tenho que ver qual tubo é bom com isso. Este motor é como um werks b2? Não foram feitos na mesma fábrica, não tenho certeza se eles são diferentes.
[/ CITAÇÕES]
I did not get to run with Sirio CL7B STI, I was to buy one in 2008 or 2009, I do not remember anymore.
Yes the Werks are made where the Sirios were, but the Werks B2 has nothing to do with a CL7B STI.
Old 08-13-2018 | 12:33 PM
  #2830
[/ CITAÇÕES]
ok thought so about same factory. *
jersey is offline
Old 01-09-2019 | 11:37 PM
  #2831
Could somebody please help me match a connecting rod for a SIRIO .27-RE/TX 7 port, designed for TRAXXAS REVO/TMAXX? I imagine the conrod I need is interchangeable with other make/model engines? I have been searching high and low to find factory specs on this engine. Any help would be greatly appreciated.
Mark714 is offline
Old 03-02-2020 | 02:02 PM
  #2832
Originally Posted by Tim Johnson
Hello everyone, I would like to let everyone know that we now have Sirio product in stock at Kyosho America. Below will be a list of parts/engines that have arrved. Give your local Kyosho dealer a call, and they should be able to order parts/engines for you.
Code:
S12T3ISTI	SIRIO 2, 1 cc EVO 3 3 PORTS SLIDE CARB. ABC SG SHAFT "IFMAR"
S23RE	SIRIO ENGINE 9 PORTS SLIDE CARB. ABC TX SHAFT - REVO
S30RS	SIRIO ENGINE BIG BLOCK* ABC 3 PORTS************* "ROTO START"
S12161010	S12 STD ROTARY CARBURETTOR
S12161040	S12 DOUBLE ADJUSTMENT SLIDING CARBURETTOR
S21161020	S21 DOUBLE ADJUSTMENT CARBURETTOR ø 10
S21161050	S21 DOUBLE ADJUSTMENT CARBURETTOR ø 10 BUGGY
S23161040	S23 STD CARBURETTOR ø 9 CASTED
S21160002	CARBURETTOR THROTTLE CARB. Ø10
S21160003	BASE SPEED NEEDLE CARB ø10
S21160103	BASE SPEED NEEDLE CARB ø10 BUGGY
S21160004	FULL SPEED NEEDLE
S21160005	INTAKE FUEL SET
S21160006	BASE SPEED ADJUSTING SET CARB. Ø10
S21160008	UNIBALL BALL JOINT
S21160009	ALUMINIUM RINGS FOR INTAKE FUEL SET
S21160010	O-RING CARBURETTOR SET
S21160011	DUST PROTECTION RUBBER
S21160012	REDUCER ø7
S21160013	REDUCER ø7,5
S21160014	REDUCER ø8
S21160015	REDUCER ø8,5
S21160016	REDUCER ø9
S23160101	S23 CARBURETTOR BODY SINGLE ADJUSTMENT
S23160002	CARBURETTOR THROTTLE
S23160003	BASE SPEED NEEDLE
S23160004	FULL SPEED NEEDLE
S23160005	INTAKE FUEL SET
S23160007	BASE SPEED ADJUSTING SCREW
S23160008	S23 UNIBALL BALL JOINT
S23160010	O-RING CARBURETTOR SET
S23160011	DUST PROTECTION RUBBER
S12160017	CARBURETTOR THROTTLE
S12160018	BASE SPEED NEEDLE
S12160004	FULL SPEED NEEDLE
S12160005	INTAKE FUEL SET
S12160006	BASE SPEED ADJUSTING SET
S12160013	BASE SPEED ADJUSTING SCREW
S12160021	UNIBALL BALL JOINT
S12160009	ALUMINIUM RINGS FOR INTAKE FUEL SET
S12160010	O-RING CARBURETTOR SET
S12160011	DUST PROTECTION RUBBER
S12160015	REDUCER ø5
S12160016	REDUCER ø5,5
S12160014	REDUCER ø6
S12160002	CARBURETTOR THROTTLE
S12160003	BASE SPEED NEEDLE
S12160007	BASE SPEED ADJUSTING SCREW
S12160210	O-RING CARBURETTOR SET
S12160022	DUST PROTECTION RUBBER
S12160020	RETURN SPRING
S12200013	FLANGED EXHAUST "EVO3"
S12200008	FLANGED EXHAUST-SILENCER KIT "EVO3"
S12060100	EXHAUST SPRING
S12060101	SILENCER SPRING
S12170001	SHAPED EXHAUST GASKET
S12170003	TEFLON SPACER S12 "SHORT"
S12170004	TEFLON SPACER S12 "LONG"
S12170005	EXHAUST SILICON RING
S21200001	STD BUGGY EXHAUST
S21200102	FLANGED BUGGY EXHAUST "LONG" "EVO 3"
S21200120	EXAUST KIT 3 CHAMBERS BUGGY PRO "EVO 3"***********************
S21200121	EXAUST KIT 3 CHAMBERS RACING PRO "EVO 3"* CONICAL EXHAUST*********************
S21170001	SHAPED EXHAUST SILICON
S21170004	SHAPED EXHAUST GASKET LONG
S21170005	EXHAUST SILICON RING
S21060100	EXHAUST SPRING
S21060101	SILENCER SPRING
S21060102	SILENCER SPRING "LONG"
S23200001	S23 STD TX MANIFOLD
S23200002	S23 STD REVO MANIFOLD
S23200003	S23 TUNED REVO MANIFOLD
S23200008	S23 TUNED REVO SILENCER***************************************
S23200009	S23 TUNED REVO SILENCER KIT
S23300002	S23 T-MAXX ENGINE MOUNT
S23300001	S23 REVO ENGINE MOUNT
S001720115	TURBO BUGGY GLOW PLUG S5
S001720116	TURBO BUGGY GLOW PLUG S6*
S001720117	TURBO BUGGY GLOW PLUG S7*
S001720126	"TURBO" GLOW PLUG S6*
S001720127	"TURBO" GLOW PLUG S7*
S001720128	"TURBO" GLOW PLUG S8*
S12021211	"TURBO" PLUG UNDERHEAD
S12030010	GASKET KIT
S12041227	S12 EVO 3 5 PORTS "ABC"* PISTON AND LINER
S12051032	S12 EVO 3 PISTON PIN
S12060012	PISTON PIN RETAINER
S12070022	S12 EVO 3 CONROD
S12081302	S12 EVO 3 I SG CRANCKSHAFT "RACING"
S12090021	FRONT BALL BEARING
S12090231	REAR BALL BEARING "RACING"
S12100010	CONE STD
S12111111	S12 EVO 3 RACING CRANKCASE
S12121102	BACK PLATE
S12130010	O-RING KIT
S12140021	HEAD SCREWS
S12140022	BACK PLATE SCREWS
S12140123	CARBURETTOR RETAINER
S12012300	S12 MT HEAD
S12021200	STD PLUG UNDERHEAD
S12041211	S12 3 PORTS "ABC"* PISTON AND LINER
S12051020	PISTON PIN
S12060010	PISTON PIN RETAINER
S12081100	S12 SG CRANKSHAFT
S12081201	S12 THREADED CRANKSHAFT "RACING"
S12090010	FRONT BALL BEARING
S12090230	REAR BALL BEARING
S12111103	S12 SE CRANKCASE
S12121100	SE BACK PLATE
S12130011	O-RING KIT
S12140025	SE HEAD SCREWS M3 x 14
S12140024	CARBURETTOR RETAINER
S18021200	S18 STD PLUG UNDERHEAD
S18030010	S18 GASKET KIT
S18041221	S18 5 PORTS "ABC"* PISTON AND LINER
S18051020	S18 PISTON PIN
S18070020	S18 CONROAD
S18130010	S18 O-RING KIT
S18150002	S18 PULL START ONE WAY BEARING
S21021200	S21 "TURBO" PLUG UNDERHEAD
S21030010	S21 GASKET KIT
S21050012	S21 "PRO" PISTON PIN
S21060000	S21 PISTON PIN RETAINER
S21070010	S21 "RACING" CONROAD
S21081300	S21 PRO CRANKSHAFT
S21090010	S21 FRONT BALL BEARING
S21090220	S21 REAR "RACING" BALL BEARING
S21100010	S21 CONE
S21113202	S21 P EVO 2 CRANKCASE
S21121101 *S21 "RACING" BACK PLATE
S21130000	S21 O-RING KIT
S21140011	S21 HEAD SCREWS
S21140012	S21 BACK PLATE SCREWS
S21140013	S21 CARBURETTOR RETAINER
S21011201	S21 "WCR" RACING HEAD
S21021201	S21 "TURBO" PLUG UNDERHEAD
S21030011	S21 GASKET KIT
S21041233	S21 7 PORTS "AAC" INTEGRAL PISTON AND LINER
S21050010	S21 "RACING" PISTON PIN
S21081301	S21 "WCR" CRANKSHAFT
S21111201	S21 "WCR" "RACING" CRANKCASE
S21140021	S21 HEAD SCREWS AND WASHERS
S21140024	S21 SLEEVE SCREWS
S21013203	BX RACING HEAD
S21013202	BK EVO2 RACING HEAD
S21023100	STD PLUG UNDERHEAD
S21023200	"TURBO" PLUG UNDERHEAD
S21043224	5+2 PORTS BK EVO2 "ABC" PISTON AND LINER
S21050010	"RACING" PISTON PIN
S21083110	STD BUGGY CRANKSHAFT
S21113200	S21 "RACING" CRANKCASE
S21123100	S21 BACK PLATE
S23012202	S23* HEAD
S23021200	S23 "STD" PLUG UNDERHEAD
S23021201	S23 "TURBO" PLUG UNDERHEAD
S23030010	S23 GASKET KIT
S23041221	S23 9 PORTS "ABC"* PISTON AND LINER
S23051020	S23 PISTON PIN
S23060010	S23 PISTON PIN RETAINER
S23070020	S23 CONROD
S23081200	S23 "TX" CRANKSHAFT
S23090010	S23 FRONT BALL BEARING
S23090230	S23 REAR BALL BEARING "RACING"
S23100010	STD CONE
S23082000	S23 BACKPLATE SHAFT
S23121101	S23 TX BACKPLATE
S23130010	S23 O-RING KIT
S23140021	S23 HEAD SCREWS
S23140022	S23 BACK PLATE SCREWS
S23140023	S23 CARBURATOR RETAINER
S27013200	"RACING" HEAD
S27023100	STD PLUG UNDERHEAD
S27023200	"TURBO" PLUG UNDERHEAD
S27030010	GASKET KIT
S27050011	STD PISTON PIN
S27060000	PISTON PIN RETAINER
S27070010	"STD" CONROAD
S27083110	STD CRANKSHAFT
S27083210	"RACING" CRANKSHAFT
S27083310	PRO CRANKSHAFT
S27090011	FRONT BALL BEARING
S27090120	REAR BALL BEARING
S27100010	CONE
S27113100	S27 CRANKCASE
S27123100	S27 BACK PLATE
S27130000	O-RING KIT
S27140011	HEAD SCREWS
S27140012	BACK PLATE SCREWS
S27140013	CARBURETTOR RETAINER
S27150003	PULL START KIT
S27150004	PULL START ONE WAY BEARING
S27084001	PULL START REAR SHAFT
S27123102	PULL START BACK PLATE
S27151000	UPGRADED PUL LSTART KIT
S30023100	STD PLUG UNDERHEAD
S30023200	"TURBO" PLUG UNDERHEAD
S30030010	GASKET KIT
S30043121	3 PORTS ECO PISTON AND LINER
S30050011	STD PISTON PIN
S30060000	PISTON PIN RETAINER
S30070010	"STD" CONROAD
S30083110	STD CRANKSHAFT
S30090011	FRONT BALL BEARING
S30090120	REAR BALL BEARING
S30100010	CONE
S30113100	S30 CRANKCASE
S30130000	O-RING KIT
S30140011	HEAD SCREWS
S30140012	BACK PLATE SCREWS
S30140013	CARBURETTOR RETAINER
S30140014	ROTO START SCREWS
Hi Tim,
I know a lot of time has passed, but i am desperately trying to find the right fuel inlet assembly (inc HSN) for a Sirio .23 Monster Power motor.
i see several on this list and wonder if you know which one goes with the .23 motor? or do you have any old paper work on the motor? It looks like you used to be right across them and supply... many moons ago tho.
cheers
Rob
Robert JP is offline
Old 08-30-2021 | 02:01 PM
  #2833
RDEERJOE's Avatar
Default Sirio .23 parts needed
Looking to find parts for a sirio .23
- Head
- backplate for bump start
- carburetor
- entire engine that’s worn out with said parts on it.
RDEERJOE is offline
Old 09-27-2021 | 12:29 PM
  #2834
Hi
I got a Sirio .12 MT and trying to source some spark plugs for it, but i found that there are Normal and Turbo plugs, tried to find if this engine it's Turbo or Normal and can't find any info, anyone knows this info ?
ruizit0 is offline
Old 09-27-2021 | 12:44 PM
  #2835
With normal plugs the hole and thread (1/4" in diameter) is completely running through, with a turbo the 8mm thread ends in a small (+/-4mm) hole.
Roelof is online now
