The AE FActory Team B44.2 Thread >
Old 12-12-2013 | 08:08 PM
  #6466
Originally Posted by mainamigo
What oils are you running bud? Ive just fitted these in my avid b44. Ill be running them indoors on slippy floor/carpet and a medium to high bite, gym running floor. (like a textured rubber almost). Running 10k front 7k rear to start.
5k front and rear. So far I don't see a need to change it. I run indoors on very hard packed dirt. Not quite clay or blue grove.
jamesbernatchez is offline
Old 12-12-2013 | 09:13 PM
  #6467
Guest
Originally Posted by jamesbernatchez
Here is the broken Durango out drive.
By looking at the out drive, the slot is too deep there not a lot of metal there to hold under the stress of power or the drive shaft is too deep in the out drive under compression and the drive shaft wedged in the out drive and broke it. I would grind off or machine off some off the outdrive. Or take all the axle shim out of the inside of the hubs to move the drive shaft out closer to the end.
Do u have a pic of the buggy put together , close up of the out drives.
kyoshoracer77 is offline
Old 12-12-2013 | 09:27 PM
  #6468
fq06's Avatar
well, my used roller arrived. Spent an hour removing servo tape.....serious who even uses that foam crap. The dives feel smooth, but I fear they might be too loose. Both fell like they are about 1/4 turn back. How tight should I run them? After 20 minutes I was able to get the mesh I liked....not fun... I had some issues with the wiring. the speed passion cap is soooo big. Its sandwiched between the servo and the esc for now. How do I go about setting the slipper for a wheeler. I am sure the hold the rear wheels and blip it if fail. Also, I dont think the previous owner sealed the CF........ I will google a video on how to do it, but do I really need to? lol.
Foam tape is evil.
Diff starting point should be 1/16 out in the front and 1/8 in the back.
Tons of pics of clean wire jobs in here to follow. Search early Rigor posts or in the first few months of the release.
Good to seal the carbon with a q-tip... like you said, Google.
Great info on slipper setting and diff build / settings, cool tool and general good 44.2 info videos in the first post of this thread. Grab a bucket of popcorn and enjoy
fq06 is offline
Old 12-12-2013 | 10:06 PM
  #6469
CarlCrocco's Avatar
Selling a complete gear diff package....
http://www.rctech.net/forum/r-c-item...ear-diffs.html
CarlCrocco is offline
Old 12-12-2013 | 10:49 PM
  #6470
Mine
Old 12-12-2013 | 11:12 PM
  #6471
Guest
Mine
That was fast!!!!!!!if carl is from st louis, him and his brother are darn good guys.
Old 12-13-2013 | 05:30 AM
  #6472
Wildcat1971's Avatar
Tech Prophet
Originally Posted by fq06
Foam tape is evil.
Yeah, I plan to redo my wiring. I was trying to not have the wires on the drive shafts nor rubbing against CF. Is the tightening of the front diff because it helps durability? or tuning? The saddle is only a 4500, but we only run 6 minutes races here, so I imagine thats plenty for a 8.5 motor. Speaking of which, I am geared 19t with the stock spur. That sound right?
Wildcat1971 is offline
Old 12-13-2013 | 05:53 AM
  #6473
fq06's Avatar
No issues with wires rubbing. Been a year on my wires and no issues... speaking of which, time to freshen up my wires.
Run the wires forward so its easier to pull or adjust the slipper.
http://www.rctech.net/forum/11886147-post3292.html
Diff just seems to want to be that tight to be right. Make a cool tool for easy adjustments.
I run a 19t / stock spur with a 6.5 so you will want a little bigger pinion.
fq06 is offline
Old 12-13-2013 | 05:58 AM
  #6474
Tech Prophet
the guy I bought it from had a 16 on it, lol. But, ok. I tell you, I hate these cams for setting the mesh. Also, when you guys "blow" the diff. So both the pinion and diff gear go? I was thinking of picking up spares because it seems like this may happen.
Old 12-13-2013 | 06:06 AM
  #6475
fq06's Avatar
They must have been running a 2.5t motor or something
Setting mesh isn't bad after you've don't it a couple times. The cam holds position really well so set screw backed out. Position cam with the two screws snug, adjust and tighten up. Too tight or loose? Back the two screws out just enough to move the cam, rotate can and tighten back up. Repeat till right. Tighten up set screw once your happy with it.
It only take me one or two stabs at it now.
I haven't had a dnf with those gears, I replaced mine about a month or so ago as they were getting a little noisy but no teeth were missing or butchered.
fq06 is offline
Old 12-13-2013 | 06:16 AM
  #6476
t0p_sh0tta's Avatar
I chamfered the edges on the CF and don't have any wire issues.
A 4500 pack is plenty big, even for 8min races.
Mesh adjustment is cake. Loosen the 2 screws 2-3 turns, and rotate the can. Set the mesh just a hair wider than you normally would, then crank the mount back down. I find that the mesh always ends up a little tighter than I like, so I compensate for that.
Whenever you have a diff go, replace both gears. I also replace them before a big race just to be on the safe side. I also shim them tight. Any movement = death. Be sure to re-check/re-shim after you put a pack or 2 on a new set.
t0p_sh0tta is offline
Old 12-13-2013 | 06:21 AM
  #6477
I go gear diffs so I don't worry as much about gears. It isn't for everyone though.
Old 12-13-2013 | 06:32 AM
  #6478
Tech Prophet
that I ended up doing the same thing with the mesh. Set it kinda loose and when I tightened the mount, it would be good. Its like gear mesh with Kentucky Windage. lol
Old 12-13-2013 | 07:26 AM
  #6479
Wildcat just as a reference for you... I run an 8.5 with timing at 22.5%. Pretty small indoor track medium bite with a good size triple in the middle. I'm running a 22t pinion and I need every bit of it for the triple. And I only come off around 108 every time
skoalisbad4me is offline
Old 12-13-2013 | 08:33 AM
  #6480
Tech Prophet
ok, I will gear up. Seems like most run 21-22 for most tracks. I am currently browning setup sheets. I am not looking to dump $100 "upgrades" into the car, but it seems like there are a few things most people do. FT ballast, LP JC wing mounts, JC tower bulkheads and the rack. I know the rack removes slop, but I will pass for now. The JC wing mounts are to lower the wing, right? The bulkheads/tower mounts. Are they durability or weight? both? The FT ballast is a pretty easyish upgrade. But is anything else required? I have some 1.4x3 pistons laying around. are they any good for outdoor small to medium,bumpy tracks? I see that most people go green rear springs and hartson even went black for worlds. So it looks like, I want to soften up the rear of the car. What about weight besides the ballast?
