Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc) >
Like Tree4Likes
Old 11-27-2013, 07:06 PM
  #2461
Budman's Avatar
Trader Rating: 22 (100%+)
My "RSD Evil Twins" !!!
Attached Thumbnails Reflex Suspension Dynamics (RSD) TC6 Upgrades (vertical ball studs, pistons,etc)-image.jpg
Budman is offline
Old 11-27-2013, 09:37 PM
  #2462
CristianTabush's Avatar
Trader Rating: 13 (100%+)
Originally Posted by alloyslash
Will you be offering the V2 mounts/hardware as a package for those who purchase the chassis only and want to upgrade to the full conversion later?
Once we fill the order for the first batch of the V2 chassis, we will look into packaging some by themselves.
As for the chassis and top deck combo without suspension mounts, we are waiting on the top decks to come in so we can take pics.
CristianTabush is offline
Old 11-28-2013, 07:46 AM
  #2463
Bigz84's Avatar
Trader Rating: 24 (100%+)
1st off, Happy Thanksgiving to RSD.
2nd, I can't wait to get my hands on the newer version. as for the top deck, just curious, have you done (I'm guessing you have) any testing w/ the stock xray top decks, and what were your findings w/ both the 1.6 and 2.0. I figured I would ask before I did any testing w/ them, to save time, possibly.lol. how does the RSD top deck change the feeling of the car?
thanks for your time.
Bigz84 is offline
Old 11-28-2013, 08:50 AM
  #2464
The new version of the chassis needs a new top deck to work properly and eliminate chassis tweak. It is similar to the spec r deck.
I don't use the 1.6 deck because it simply provides too much flex. Our car, with the lowered layshafts and our top deck is one of the most flexible set ups out there.
However, if you make your car too flexible, it gets hard to drive.
Old 11-28-2013, 01:02 PM
  #2465
Brooksracing's Avatar
Cristian
I will be running my RSD6.2 at the Stafford Nationals here in the UK (medium grip carpet, fairly technical circuit on sorex 28 with blue inserts) On the 8th December, I have only ran the car on asphalt so far. The last order from yourself should arrive by then meaning I can rebuild the dampers with your 0 rings, 611 pistons and 800 WT oil. I'm looking for some advice on spring choice (I have a full set of your springs), roll bar choice and damper position?
Any help would be much appreciated. I am running 13.5 boosted.
Tom
Brooksracing is offline
Old 11-29-2013, 09:12 AM
  #2466
Trader Rating: 27 (100%+)
Do you have a recommended setup sheet for the RX4 on low-medium carpet? This is for racing at Mikes.
Also, I just ordered your RSD replacement driveshafts for the Xray ECSs. Everything is incredibly tight and it won't move freely. I can't get the little coupling piece on the inside back out once I put it in there.
hyujmn is offline
Old 12-02-2013, 09:40 AM
  #2467
I don't have a set-up for Mike's. Sorry, but I would start with the default RX4 set-up from the instructions and adjust from there. Maybe softer springs for Mike's? I have not been there in over a year and have never run my XRAY there.
With the DCJs, sometimes they can be a bit tight when new. We put a special coating on them so that they are a little more snug, which increases life. What you need to do is make sure they are greased up with some black grease or Hudy Graphite Grease. Then work the dcj in your hands once assembled a little in each articulating direction. After this, they should free up a bit.
Once they are a bit freer, install in your car. Place your car on a car stand and at a bout 1/4-1/3 throttle, turn your wheels full lock right for 30-45 seconds to each side to break them in. Once you do this, they should be very free and they will be ready to hit the track.
Old 12-02-2013, 12:41 PM
  #2468
I came across a small batch of Block Locks and Silver Gen 1 TC6 springs. If you guys want them, they are on the site.
Old 12-02-2013, 11:14 PM
  #2469
Hey, Christian.
I tried doing what you said with the DCJs. The barrel inside the dogbone is still incredibly tight and won't move at all. I installed it and did the whole "light throttle for 30-45 sec" thing but it continued to bind and eventually the pin just popped out entirely. Now, it's tight to the point that I can't even center the barrel to install the pin through the coupling.
Is there ANYTHING else I could try? The barrel is still ridiculously tight inside the dogbone and I can't install any of the other ones because they're just as tight.
hyujmn is offline
Old 12-03-2013, 01:25 AM
  #2470
alloyslash's Avatar
Trader Rating: 19 (100%+)
Somehow you'll need to press the barrel back out of the bone for now. If you have a set of digital calipers, check the ID of the bone for roundness, as tight of a tolerance these things are engineered with a 0.02 difference in roundness will cause binding issues
What I do any time i am assembling a new set it find a drill bit that's diameter is LARGER than the hole inside the barrel, but SMALLER than the outside of the barrel. Coat the hole with Hudy Graphite grease. After installing the barrel inside the bone, place the tip ( barrel end ) on a hard surface. With the bit in a drill, press the bit against the barrel and spin it while holding the opposite end of the bone. The bit grabs ahold of the barrel and spins it inside the bone. Usually after a minute or two of this there is no longer any sort of resistance whatsoever. I then remove the barrel, coat it with Hudy Graphite grease and re-install. After completing the assembly I chuck the bearing / wheel end of the DCJ into my drill, loosly hold the opposite end of the bone between 3 fingers and spin it at WOT for 2-3 minutes at as much angle as the DCJ will allow. The end result is a completely broken in assembly, super free and ready to race. There is numerous ways everyone sets their stuff up, this is the way that has worked every time for me.
alloyslash is offline
Old 12-03-2013, 05:48 AM
  #2471
Originally Posted by hyujmn
Hey, Christian.
You just probably have a defective piece then. Please contact the store with you contact details and we will send a replacement bone and some barrels.
Old 12-03-2013, 01:33 PM
  #2472
adriang79's Avatar
Christian, any idea when you will have the TC6.1 aluminum spool cups back in stock?
adriang79 is offline
Old 12-03-2013, 03:49 PM
  #2473
Probably sometime in early January.
Old 12-05-2013, 10:36 AM
  #2474
Top decks arrived! All RX4 V2s are in packing now and should be shipped out by Monday evening.
Old 12-05-2013, 11:01 AM
  #2475
erchn's Avatar
Nice!
erchn is offline
