VBC Lightning 12 >
VBC Lightning 12
Like Tree3Likes
VBC Lightning 12
Old 11-21-2013 | 03:45 PM
  #151
Jerry P's Avatar
Originally Posted by S.Stew
Dave Johnson has a photo on his facebook showing his lightning 12 and it's got quite a tall rollover antenna on it. Maybe he can explain...?
Dave Johnson where you at? We need answers.
Jerry P is offline
Old 11-21-2013 | 07:20 PM
  #152
pbr
Well order one hope to have it done for minrig for the shoot out
pbr is offline
Old 11-21-2013 | 07:55 PM
  #153
IIGQ4U's Avatar
Dave said he used a rollover antenna shaved down to fit in the shock mount hole with Shoo Goo.
IIGQ4U is offline
Old 11-21-2013 | 08:25 PM
  #154
Originally Posted by dr_hfuhuhurr
VBC, if you are following this thread, please make a shock mount with a rollover antenna. Or anyone out there in the hop-up world, that would be acceptable as well. Please don't make us run without our rollover antennas.
You can use M3x8 set screw with our A-03-VBC-1043 antenna mount to secure it on one of the shock mount hole. http://cdn.shopify.com/s/files/1/016...d66cdb.jpg?962
vhmlaw is offline
Old 11-21-2013 | 08:46 PM
  #155
dr_hfuhuhurr's Avatar
Brilliant! That will work.
dr_hfuhuhurr is offline
Old 11-21-2013 | 09:17 PM
  #156
JayBee's Avatar
JayBee is offline
Old 11-23-2013 | 10:47 AM
  #157
MAD916's Avatar
OK Most of the way there about 70 Lightning Parts up on the online store
http://www.timezonehobbies.com/index...Path=2_105_109
More parts and kit's coming in this week
MAD916 is offline
Old 11-23-2013 | 09:45 PM
  #158
andrewdoherty's Avatar
A couple VBC questions...
Can anyone verify if the VBC center shock will accommodate typical AE/CRC center shock springs?
Is the front kingpin 3.0 or 3.3 mm in diameter?
What is the "inside" length of the front kingpin? The length of the equal signs in this Mona Lisa of a picture. (|======|
AWD
andrewdoherty is offline
Old 11-23-2013 | 11:20 PM
  #159
Hey AWD! Standard AE/CRC springs will not fit on the stock VBC center shock, as the ID of those springs isn't big enough to fit over the VBC shock body.
Mine measure just over 3 mm, right around 3.05-3.08 mm.
The distance from the inside of the bottom collar to the bottom of the button-head screw (at the top of the kingpin) measures right at 28.6 mm on both of my kingpins. I think this is just a hair longer than the AE kingpins (from clip to clip.)
If you have any other questions, feel free to ask.
LloydLoar is offline
Old 11-24-2013 | 07:34 AM
  #160
Thanks a ton Chris. I appreciate you taking the time to check those for me.
Old 11-24-2013 | 08:16 AM
  #161
ATLiens's Avatar
All I can say about this car is WOW! I finished assembling the car yesterday morning just in time for qualifying at the Georgia On Road Championships. I qualified 2nd in the Amain behind my buddy Fernando Gordinho who was also running the lightning12. Unfortunately I was hit from behind in the first turn and my motor slipped forward. I pushed the motor back and tightened it down. After missing 5 laps I threw it back on the track and the car drove amazing. I finished 5 laps down on Fernando, had the fastest lap time with three 9.1's. If I had a better start Fernando and I would of had a blast pushing each other for the win.
I setup up the car with a tamiya touring car shock in the center with an extra long ball cup. 4wt shurlube in the link tubes, stock front springs, blue AE rear springs, 0 toe out, 1mm camber, 3.6mm ride height all around, Parma black fronts, pink rears, Viper vtx1 speedo, Trinity d3.5 13.5, Orca 6500mah, protoform amr12 body.
I have owned the xray x12, AE12r5.1, 12r5.2 and now the lightning 12... By far the best 1/12 scale I have driven.
ATLiens is offline
Old 11-24-2013 | 01:03 PM
  #162
corallyman's Avatar
AWD
Hey AWD,
I had a good look at a friends car yesterday. If you are looking at keeping the lightening's shock which seems really nice, Serpents s120's center shock springs look like they would fit if you were looking for more choices. I think there are 5 springs.
Steve
corallyman is offline
Old 11-24-2013 | 01:17 PM
  #163
JayBee's Avatar
Oh, So N O W we're friends
Seriously though buddy, thanks. I'm gonna look into that
JayBee is offline
Old 11-24-2013 | 01:27 PM
  #164
corallyman's Avatar
Hey Jaybee,
I just said that I had a good look at a friend's car....i didn't say I had a look at a good friends car!!
Old 11-24-2013 | 01:58 PM
  #165
JayBee's Avatar
Touche'
JayBee is offline
