Anyone else having or had VP 30/9 fuel issues ?
#17
What do you mean user related? Until it happens to you huh! I was a VP supporter but with the only 6 engines going south in 6 months between 3 of the most exp guys in the area who have got 8+ gal out of their engines in the past all Novas and same engines having rear bearing issues after a 1/2 gal - 2 gal of the same batch of fuel its got to be a lubrication issue so I would bet the farm on it! I am so sure now that I am not even going to send a new engine back to the distributer and bite the bullet spend my money again to fix it myself!
#18
I have been racing nitro for close to 14 years now. I have used all of the fuels, Byrons, Sidewinder, VP, Rocket Science, Omega, Dynamite, etc. In my time I have had some bad batches of fuel but all I suffered was random flameouts or just no way of getting a motor to tune. I have never to the day had a rear bearing go out. Not trying to sound like a wise guy but I guess I am just lucky. I have been using VP for about 2 years now and have not had any issues. I have an OS thats on 12-13 gallons as we speak and still kicking. Still has the original rear bearing, replaced the front once due to leakage.
#19
#20
It's always possible that a bad batch of fuel got out. I have been running Nitro for a long time and I have seen bad fuel come out from pretty much every brand. Do any of you remember the bad Sidewinder a few years ago? Unfortunately it is mixed by either people who can make mistakes or machines that are monitored by people who can make mistakes. The factories are not going to recall or check which ones may be tainted. Its cheaper to pay for an engine here and there if somone can prove it and raises a big enough stink!
#23
All I can say is I don't run it, my two most trusted engine dudes don't like it, however, if you like it go for it. I know plenty of guys that run it. To each his own. I can say plenty of bearings have been replaced. Not bad on holding compression though, and seems to do fine on the track.
#25
#26
The part number is the same as before, but the balls are smaller diameter than before!
Anyone who have bought a Nova with a metal rear bearing, needs to change it at 2 gallons, that's my opinion.
#27
After switching to Byron's from VP I had to lean the Hsn and Lsn almost a full turn with both engines I run and that is a sign of a better fuel IMO!
#28
from what I see this fuel is all over the map with consistency...Some of it seems to run extremely good and some of it seems to run very poorly....Some of the engines seem to wear normally, others show very rapid wear and of course some with catastrophic wear....
#29
I have seen occasional bearing failures on nova engine (cant really say it wasnt improper break in induced problem butttt) with all different fuels , I can also honestly say I personally see 6 gallons (ish) on any of my bearings with proper tune , fuel and storage . Never leave engine in humidity , never run engine out of fuel/lube and if you are gonna leave your engine in the race vehicle til next race leave it pointing nose down
hope this helps
I agree with Neal on last post
hope this helps
