The AE FActory Team B44.2 Thread
#5866
On the Reedy 737 there is no balance plug on the batteries...so...you dont balance them like a full size pack. You need this:
http://www.amainhobbies.com/product_...llet-Connector
The white plug would plug into your charger/balancer.
#5867
#5869
#5870
#5872
If you have never rebuilt them (which it sounds like) check the backside of the diff rings and thrust rings. You may be able to flip them. Otherwise get some 600 or higher sandpaper and sand them smooth, plenty of writeups on it.
#5876
http://www2.wattflyer.com/forums/sho...0&postcount=19
#5877
I would also replace the gears while you have it apart (PN 3914), they're only $6 or so.
Take a good close look at your balls to ensure they haven't worn out. I always replace them when I rebuild my diff. I rebuild mine about twice a year, although I don't get a lot of track time in (once per week if I'm lucky).
#5879
Also make sure you have some motor spray/brake cleaner to clean the grease off the parts along with diff lube (PN 6591) and black grease (PN 6588).
I agree that you must inspect and replace suspect balls. if the diff is over 6 months with regular use, just replace the balls, its not expensive.
#5880
