Rw modding and engine rebuilding >
Like Tree28Likes
Old 08-08-2013 | 08:26 PM
  #301
22Racer's Avatar
Originally Posted by houston
Yikes
Thats craziness
doesnt look that tini coating worked out to good
The Go's came with the Tin coating for a while. It actually worked out pretty good, about 2x the life. This one must have gotten some dirt in it at some time.
Rex
22Racer is offline
Old 08-20-2013 | 10:35 AM
  #302
ovalracer1m's Avatar
Here is a S852 i just got back from rex. He machined the snout for the nova caps. They fit sooo much nicer and tighter than trying to use alpha caps on a unmachined alpha block.
As you can see, rex does a professional job and would not hesitate to have this done again. More than pleased
ovalracer1m is offline
Old 09-02-2013 | 06:36 PM
  #303
hey i have a quick question i have a motor i have not ran for a about a year and a half. i always put oil in it like every couple of month and rolled over the fly wheel to lube it up. i went to race the monster truck class to find out the engine sucked bad. i ended up changing the fuel lines and tank. to get it to run somewhat then somewhere in the race my filter came off in a hit in the air and i landed top side engine died before i hit the ground good thing. so i hit the bench looking at the carb and i had some dirt in it. so i called it a day with that class. just pulled it all out cleaned it all up put the cam back in it and the front bearing seal pop right out. now i thinking it need a new front bearing re did all the rings and lube it all up real good. run alot better now but it still sucking up air and running lean some how every now and then. so you think it the front bearing did not get lube up good enough. i can just turn the fly by hand and the piston come right out i so i know it not that part.
imrob is offline
Old 09-02-2013 | 07:49 PM
  #304
22Racer's Avatar
You just popped the seal on the front bearing back in? It probably needs a new front bearing. What kind of egnine is it?
22Racer is offline
Old 09-03-2013 | 03:51 AM
  #305
It a traxxas 3.3 and yes that what happened
imrob is offline
Old 09-09-2013 | 07:47 PM
  #306
22Racer's Avatar
Congrats to Stanley for taking 2nd at the Indonesian National Race #4 with his Rw modified Os Speed spec 2!!
Usually this time of year things start thinning out, still getting resize orders but mostly engine rebuilds and modifying. Keep sending the engines!
Rex
22Racer is offline
Old 09-16-2013 | 03:00 PM
  #307
Motorman007's Avatar
Just to say REX helped me out again.
I don't want to start a new thread for this.
Any one knows where I can get parts for this motor a buddy of mine has one but needs a button and head for it. The p/s is new rod new crank new he missed placed it before he went to Iraq
MAX-21VZ-B(P) Model: 13886
Rex found me a new head and shims and Button for this motor.
For a very very Fair price.
Thank you for your time and work on this for me sir.
Motorman007 is offline
Old 09-30-2013 | 05:52 AM
  #308
Rubble01's Avatar
hello are the race prepped motors that you sell on the webpage
are the broken in or do they need breaking in
Rubble01 is offline
Old 10-01-2013 | 06:19 PM
  #309
22Racer's Avatar
The Only engines I have listed as Race prepped are the Trackstar. They are not broken in, I actually give them a bit of a pinch because they come with no pinch at all new. They are lightly modded and checked over also.
Rex
22Racer is offline
Old 10-10-2013 | 04:54 PM
  #310
22Racer's Avatar
10% off all engines until Oct. 27 and free lapping on any engine to help break in!!
I also will be unable to service any engine the first half of November.
Rex
22Racer is offline
Old 10-11-2013 | 04:48 PM
  #311
Hi Rw
Interest in a modded hudy fx engine ... What do your mod does? Runtime ? Power? More top end?? Also what pipe do you suggest with your mod?
segreda is offline
Old 10-11-2013 | 05:46 PM
  #312
22Racer's Avatar
Originally Posted by segreda
Hi Rw
The Fx has plenty of low end, it would pick up in the middle and give it alot more top end. Depends on if it was for a Truggy or buggy. It will increase runtime but every driver is different. I would recommend the Fx 2108 but there are plenty of other pipes that will work also.
Rex
22Racer is offline
Old 10-11-2013 | 06:44 PM
  #313
Pm send
segreda is offline
Old 10-11-2013 | 11:30 PM
  #314
B00t13g's Avatar
What have you found the differences to be between the 2108 and 2100? The 2100 looks like a nova 9901 and the 2108 looks like an os2090 to me anyway.
B00t13g is offline
Old 10-12-2013 | 09:17 AM
  #315
22Racer's Avatar
I have not tried the 2100, it was not available when I ordered my Fx engines. I do not like to go by the way a pipe looks, the internals can be so much different also. Hudy put out a nice pipe chart.
Rex
22Racer is offline
