Like Tree5Likes
SC10 4x4 Thread
Old 09-26-2013 | 11:08 AM
  #35116
StPete40's Avatar
Lacking scales, whats the best way to determine left/right and front/rear balance? Not interested in nanograms, just general balance.
StPete40 is offline
Old 09-26-2013 | 11:31 AM
  #35117
Cain's Avatar
Originally Posted by StPete40
Thanks Cain, I will be running on a couple of outdoor 1/8 tracks. Some very loose conditions sometimes on non-race/practice days. I'd really appreciate any setups you have.
I bought the VTX8 for the ease of adjustment and the PRO4 HD knowing I will be moving to a different chassis later. Running TP Pro Race stick packs so should be fine there.
I can make the Exotek hub carriers and front locker happen easy enough. Would get the Exotek chassis if I found the right deal. Don't want to invest in a new one at this point.
Shoot me your email address and I can forward it to you. Feel free to adjust to your liking and report back your findings.
Cain is offline
Old 09-26-2013 | 11:59 AM
  #35118
GraphiteChassis's Avatar
Originally Posted by Cain
Someone has done this in the past. I don't recall what all they chopped out if anything, but it has been done and posted on the thread.
Tip: use the Center Diff for the best performance, no multiple pads required.
I did a full stick pack in the center. I milled out to the rear most bolt for the top brace to chassis. The flex was too much after that. The car drove better in general with center full stick... I liked it anyway. But, way too much flex.
I ended up going back to (after new chassis) forward saddles.
GraphiteChassis is offline
Old 09-27-2013 | 10:15 AM
  #35119
Wild Cherry's Avatar
I just go by Ae's Factory drivers recommendation ...
Seen weight added next to spur to help offset the 550 motors extra weight ...
Some add 1oz on the back side of the saddle pack & also seen 1/2 oz on the front corners of the chassis behind the servo ..
Most of the team adds weight on both sides of the servo , up to 2 1/2 oz on each side ...
Wild Cherry is offline
Old 09-27-2013 | 10:24 AM
  #35120
fq06's Avatar
Tie fishing line to both towers and pick it up at the center. Not as precise as scales but then again you need solid shafts to replace the shocks to get chassis weights. Shocks on is suspension corner balance after you have balanced the chassis.
fq06 is offline
Old 09-28-2013 | 11:27 AM
  #35121
Raining hard here in Tacompton .......
OMW to track to enjoy my Lite Sc10 4x4 set-up...
Drives & performs like a dream ......
Why does it drive so good ?
VTS QUAD PAD SLIPPER lays down every bit of my Reedy Sonic 550 4.5 power to the track ....
Old 09-28-2013 | 12:14 PM
  #35122
Cain's Avatar
wow, the Center Diff must give extra power then
Cain is offline
Old 09-28-2013 | 12:19 PM
  #35123
lol. i sold my sc10 4x4 nearly half a year ago and still read this thread every day because of the trolling xD (and of course also some useful information)
Cody227 is offline
Old 09-28-2013 | 12:22 PM
  #35124
Cain's Avatar
lol.
Heck, I am curious though if AE will release a light setup of the SC10 4x4 in the future. When I talked to a rep there, the initial impression I got was the SC10 4x4 for indoors where it shines, and maybe a 1/8 based one (no slipper though was mentioned ) for outdoor tracks where 1/8 based vehicles like the Tekno and Losi shine.
Maybe they could really run with it?
Cain is offline
Old 09-28-2013 | 12:38 PM
  #35125
fq06's Avatar
Example of an oxymoron:
VTS QUAD PAD SLIPPER lays down every bit of power
Its a, wait for it... wait for it... slipper.
fq06 is offline
Old 09-28-2013 | 12:43 PM
  #35126
O6
that slip
beats spinning tires and casing easy doubles ....
Old 09-28-2013 | 12:44 PM
  #35127
Cain's Avatar
When is the RC8 slipper available?
Cain is offline
Old 09-28-2013 | 01:34 PM
  #35128
fq06's Avatar
Instead of double singling with the slipper I would prefer to triple with the C-Diff
fq06 is offline
Old 09-28-2013 | 02:20 PM
  #35129
StPete40's Avatar
Anyone have the part# for the non-ft outer diff hub that is required with the center diff?
StPete40 is offline
Old 09-28-2013 | 03:42 PM
  #35130
not, you only case the double before the triple
Just like Cam did ..
ha !
