Help 4s lipo charging problem >
Old 09-23-2013 | 02:15 PM
Default Help 4s lipo charging problem
Just got a 4s lipo that came with a car I bought I tried balance charging it on my hitec x1 but the charger only detects 3 cells. I plugged in my cell meter and I'm getting.
Total 12.79
Difference 2.649
Cell1 3.825
Cell2 3.730
Cell3 1.274
Cell4 3.926
Is there any way to safely bring this back to life?
Gvm23 is offline
Old 09-23-2013 | 06:47 PM
You can set the charger to nimh charge mode at the lowest amp setting, charge cell 3 until it's close to the others, then switch back to lipo charge mode and finish charging. You'll have to sit and monitor the whole process start to finish.
Johnnysplits is offline
Old 09-23-2013 | 06:55 PM
ThePanda's Avatar
if a cell is off by that much there isn't really much you can do. charging in nimh mode will charge all cells, like it does to a nimh battery i would just recycle the battery.
now that i look at it the cells are off by quite a bit. 2/10 is quite a lot.
ThePanda is offline
Old 09-23-2013 | 06:56 PM
That's what I figured, thanks
Gvm23 is offline
Old 09-23-2013 | 06:58 PM
ThePanda's Avatar
you could try, but i think you would get an unwanted fire.
ThePanda is offline
Old 09-23-2013 | 07:01 PM
Yeah I'd rather not have that Lola's thinking maybe discharge which should only discharge the high cells but I'm not sure on that. Then do the nimh to get it back within range to register as lipo
Gvm23 is offline
