Savox problem
Hey guys I got a savox sc-0251, was working fine for quite a while, then it became suddenly sluggish, and on the next run it quit entirely. I plug in a freshly charged rx pack, turn radio and everything on, and the servo does nothing. I know everything else works. I took it apart and cannot find any broken solder joints, motor still feels okay, no stripped gears, whats the problem here? Is this fixable?
Assuming someone hasn't messed with your radio settings, try another servo if you have one just to make sure it is not a receiver (internal circuitry) issue. If that servo works fine, it is something internally in the servo circuitry. Probably best just to replace it in that case.
You could also try XQ-S4016D,14kg~16kg torque,even much faster than your former one.
Dimensions(mm): 40.2X20.1X38.8
Weight(g): 56g
Weight:56g ±0.2(1.46oz);
Gear type:Titanium Gear;
Speed:0.12sec/60º at (6V)
0.13sec/60º at (4.8V)
Torque
219.4 oz-in)15.8kg.cm.at(6V)
(201.4 oz-in)14.5kg.cm.at(4.8V)
Weight(g): 56g
Torque
219.4 oz-in)15.8kg.cm.at(6V)(201.4 oz-in)14.5kg.cm.at(4.8V)
