-   -   Savox problem (https://www.rctech.net/forum/radio-electronics/753512-savox-problem.html)
Upbasher 08-23-2013 06:31 PM
Savox problem
Hey guys I got a savox sc-0251, was working fine for quite a while, then it became suddenly sluggish, and on the next run it quit entirely. I plug in a freshly charged rx pack, turn radio and everything on, and the servo does nothing. I know everything else works. I took it apart and cannot find any broken solder joints, motor still feels okay, no stripped gears, whats the problem here? Is this fixable?
seabass17 08-23-2013 06:43 PM
To be honest here you should consider just buying a new one they are 35 bucks give or take. It would probably cost that much to send it in for repair.
Banshee8530 08-24-2013 01:49 PM
Assuming someone hasn't messed with your radio settings, try another servo if you have one just to make sure it is not a receiver (internal circuitry) issue. If that servo works fine, it is something internally in the servo circuitry. Probably best just to replace it in that case.
Upbasher 08-28-2013 04:22 PM
Alright guys thank. Sorry for not replying...I forgot I posted this until now, lol
Do you think I should buy another savox or should I spend an extra $40 and get a hitec hs 7954?
theblitzkidd 08-28-2013 04:28 PM
I don't think u should, I kno u should, that is a very good servo! HITEC makes one of the best servos ever, and they have amazing CS reps as well:)
Upbasher 08-28-2013 04:46 PM
Great I will get a hitec then
theblitzkidd 08-28-2013 07:41 PM
Good, trust me, u will not regret it:nod: :)
Ketty 09-05-2013 07:25 PM
XQ-S4016D,your choice
1 Attachment(s)
You could also try XQ-S4016D,14kg~16kg torque,even much faster than your former one.
Dimensions(mm): 40.2X20.1X38.8
Weight(g): 56g
Weight:56g ±0.2(1.46oz);
Gear type:Titanium Gear;
Speed:0.12sec/60º at (6V)
0.13sec/60º at (4.8V)
Torque:(219.4 oz-in)15.8kg.cm.at(6V)
(201.4 oz-in)14.5kg.cm.at(4.8V)
Attachment 1108994
