Team Associated B4.2 Thread >
Like Tree4Likes
Old 08-13-2013 | 11:39 AM
  #8101
I go about 6 to 8 weeks , I run the car 15 to 20 runs a week .
I replace the out drives , CVA & bearings, transmission gears , diff ring..
Still using the same thrust for almost 8 months now ...
If you are running on dusty outdoor ?
space a small bit of cotton from Q tip under the thrust seal cap .
What do your outdrives look like when you replace them? Mine do not show wear 8 weeks in.
chevmaro is offline
Old 08-13-2013 | 11:44 AM
  #8102
8 weeks with no wear must be stock racing?
Any car I've ever had with 10+ runs/week would have notchy outdrives after that much time and be noticeably unpredictable handling-wise until they were replaced.
BryanJ is offline
Old 08-13-2013 | 01:29 PM
  #8103
metalnut's Avatar
How much slop do you guys have in the dogbone couplings before you replace them? My rear wheels have enough slop in them that I can rotate them a significant amount back and forth without moving the outdrive. It seems to be coming from the coupling by the looks of it. I'm guessing it's time for new dogbones?
metalnut is offline
Old 08-13-2013 | 01:37 PM
  #8104
Wildcat1971's Avatar
Tech Prophet
My drive terrain is solid after a year. But I run stock on low bite
Wildcat1971 is offline
Old 08-13-2013 | 02:08 PM
  #8105
ryanpatrickgore's Avatar
Yea the mod drivers are the ones who are really tearing up the out drives.
ryanpatrickgore is offline
Old 08-13-2013 | 03:05 PM
  #8106
YankeeFan123's Avatar
Mine are like that also where there's a significant amount of play. I would think the out drives and dogbones would have to be replaced at the same time or else the worn dogbones would wear out the new out drives and vice versa
YankeeFan123 is offline
Old 08-13-2013 | 03:06 PM
  #8107
Also, if anyone wants my XP 1015 servo that started to crap out on me for parts or you know how to take it all apart and find the problem, PM me and I'll give it to you, just pay for shipping to wherever.
Old 08-13-2013 | 03:20 PM
  #8108
ChrisAttebery's Avatar
How big is the track you're running on?
Originally Posted by YankeeFan123
I run 33/72 with 39* timing with my SchuurSpeed
ChrisAttebery is offline
Old 08-13-2013 | 03:27 PM
  #8109
Not sure, pretty decent sized tracks, OCRC or West Coast in SoCal
Old 08-13-2013 | 03:59 PM
  #8110
Jsaves's Avatar
Default Loose Track set up?
Wildcat1971,
What set up are you using? I run on an out door drying loose track. It has a hard pan underneath and a loose silt on top.
I am running the following set up.
Tires - m3 hole shot fronts, green goose bumps rear & stock foam on both.
Front :
Shocks - Green spring, 2 x 1.6 flat, 30 wt, 1 tower, O arm
tie rod - 1 in (2mm washer) and A out 30 deg. caster
Rear:
Shocks - White spring, 2x 1.6 flat, 27.5 wt., 1 tower, I arm
tie rod - 1 in (2mm washer) and B out, 0 deg. hub
This Steven Hartson set up
The buggy is loose on power
Thanks for any help
God Bless
Jsaves is offline
Old 08-13-2013 | 04:09 PM
  #8111
trixter91's Avatar
We run on a medium size track with a few decent straights and a few small jumps. I was thinking of replacing my full size packs with some shorty packs . I was told that the b4 was light and worked better with the full size packs as opposed to shortys. Anybody know what the benefit of a shorty vs a full size is other than the weight.
trixter91 is offline
Old 08-13-2013 | 04:39 PM
  #8112
Tech Prophet
Originally Posted by Jsaves
Wildcat1971,
Front :
Rear:
Thanks for any help
God Bless
IMO, white is too stiff in the rear, I would go green. I really dont like the 1.6 pistons much at all. My personal favorites are the 1.4x3 pistons. If they are too pricey for you, try the 1.7's with 37.5/32.5 oils.
Old 08-13-2013 | 04:56 PM
  #8113
Wild Cherry's Avatar
Naaa , just the amount of runs ....
Maybe stock wears a little less but not much less....
17.5 is nothing but a mild mod motor these days ...
All new parts make for consistent cornering & forward traction at it best .
Wild Cherry is offline
Old 08-13-2013 | 05:02 PM
  #8114
Car handles & traction is much the same as a with full size pack.
Jumping & landings are improved ....
Old 08-13-2013 | 05:15 PM
  #8115
trixter91's Avatar
So do u suggest using shortys over full size packs.
