Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 07-25-2013 | 12:24 AM
  #121
I did mount the 48T pinion in combination with a 90T spur, cause i Always use tamiya spurs and pinions and that's the smallest spur tamiya has.
addicted2blue is offline
Old 07-25-2013 | 11:40 AM
  #122
Here are some pictures of my fresh painted Ferrari 458 body for my TA06 PRO, TA05R and my TT-02.
No decals used only paint, will be testing the body this wknd.
bertrandsv87 likes this.
Old 07-30-2013 | 07:34 AM
  #123
Hi guys,
Got my TT-02 kit, read a bit of the manual, and will be building it during weekend, just wanna know your setups while building, in the manual there's a 'short' and 'wide' setup, and i'm just planning to go 'wide' and all 'standard' for the rest. Will it be ok or should i go 'standard' all around? And with the 'wide' setup, will the four wheels be too wide for the body shell and looks akward?
Also, is there anything i should know before the build?
I'm just new with this on road thing and this is gonna be my first build.
Thanks a lot for any help i can get.
basher88 is offline
Old 07-30-2013 | 07:50 AM
  #124
The manual will tell you what to do to fit with your shell. If you want to use std shells do the standard setting
here is a build review which covers all the steps
http://www.thercracer.com/2013/05/ta...nd-review.html
Stage one shows where to look in the manual
Qatmix is offline
Old 07-30-2013 | 09:18 AM
  #125
Hi Qatmix,
Thanks a lot for all the help, actually i've been following this thread, and thank you so much for all the great reviews and contributions to this thread, and please keep 'em coming sir, cheers
basher88 is offline
Old 08-02-2013 | 07:04 PM
  #126
Bearings and Upgrade the front and rear knuckles. Stock break way too easy. Aftermarket front knuckles allow more turn and in bump go to far and let dog one pop out. So need Cvds
itsfishi is offline
Old 08-03-2013 | 01:26 AM
  #127
My little girl drove the TT-02 a week ago in a junior race and she did break 2 steering blocks, luckely i was able to fix them but this is really a spare part you need to have.
They are indeed very weak.
I've also build an extra bridge at the front of the steering arms, this will reduce a lot of steering slob.
Old 08-05-2013 | 01:29 AM
  #128
ahhh, experience this several times, even on light impact with other car. what i did before changing to alums is i added anti wear grease. So the twist and friction is quite draggy but smooth. added shims on the upper arms so the knuckles doenst wobble on turns. and tightly screwed the bottom part of the knuckle and a .2 or .3mm extra screw space on top.
chowmarcochow is offline
Old 08-05-2013 | 11:37 AM
  #129
We can't use alu suspension parts, we can only use Original tamiya parts at the belgian tamiyacup series.
Old 08-05-2013 | 01:29 PM
  #130
I bought 12 tto2 for rentals at our track and have broken 18 rear knuckles now replaced with alu. I had one kid break 5 in about 40 mins and was ok driver lol. Tamiya has dropped the ball on this one
itsfishi is offline
Old 08-06-2013 | 12:34 PM
  #131
I've mounted a Speedpassion V3 21.5T motor with a cirtix stock club esc, will test this combo thursday night at our club that will be re-opened after a summer stop of 6 weeks.
Very excited about driving the car on carpet, have high hopes.
Old 08-06-2013 | 03:16 PM
  #132
Tamiya have another shaft car, The TB04 !
http://http://www.rctech.net/forum/e...ro-thread.html
I wonder if anything can be swapped onto the TT02?
Qatmix is offline
Old 08-06-2013 | 11:24 PM
  #133
Those were the things i did when i use plastic knuckles. Dont let the arms wobble so much and use anti wear grease.
Old 08-09-2013 | 03:33 PM
  #134
Hi, I am looking to get back into the hobby after a long break. The last car I has was a TB01 would this be a good car? I am also looking at the TB04 but this is already available at my local hobby store. Also can you get a front one way for this car?
shaftboy is offline
Old 08-10-2013 | 05:51 AM
  #135
I thought the TT-01 front one-way option part (53671) is a direct fit for the tt-02 chassis.
