Team Associated B4.2 Thread >
Like Tree4Likes
Old 07-14-2013 | 08:20 PM
  #6796
Skillz_B's Avatar
I forgot all about the Lunsford, probably because they are so expensive, I think the B4.2 kit is around $90, they do save weight though.
Skillz_B is offline
Old 07-14-2013 | 08:21 PM
  #6797
DanielC.'s Avatar
Like it or not ....
B4 was designed for the old NiMH ...
Still needs a certain amount of weight to perform at its best ....
Says the person running a shorty pack?
DanielC. is online now
Old 07-14-2013 | 08:27 PM
  #6798
Wild Cherry's Avatar
A Shorty plus 40 grams of ballast in rear battery tray .....
also
7 grams in each rear corner & a team ballast in front of transmission...
Car feels better, has better balance in the air & landings ,a bit more off power steer then a full size 25C ...
Using a 7.5 Reedy
Wild Cherry is offline
Old 07-14-2013 | 08:28 PM
  #6799
YankeeFan123's Avatar
101 to be exact I looked them up, at least on the Lunsford site
YankeeFan123 is offline
Old 07-14-2013 | 09:11 PM
  #6800
ryanpatrickgore's Avatar
I just got back from practice at trcr after the races were over and the grip was awesome. I have been running same shock setup as WC, but today went back to 30wt oil in the rear and I felt like I had a bit more grip. Then after a while I tried my kyosho springs... Pink/gold . I beat my fastest lap of the session 2 times. By just a few tenths but.. the Kcar springs were feeling really dialed tonight. Anyone else using them??
ryanpatrickgore is offline
Old 07-14-2013 | 09:54 PM
  #6801
Originally Posted by chevmaro
how do pro's always keep there cars looking so clean? Mine looks like crap after like 2 races haha.
Just use armoral man, you probally have some laying around. put it on a tooth brush and rub it on. keeps it looking good
xTotalghost is offline
Old 07-14-2013 | 10:16 PM
  #6802
Originally Posted by bds81175
Reduce front droop a titch, decrease anti-squat a tad, decrease rear toe a skosh (careful with that one, you can quickly lose rear traction other places), decrease caster.
Ok I realised I haven't given my setup details:
1.6 piston all round, 3 limiter front and 2 in rear. 30/27.5wt F/R oil. Green springs all round.
Full Stick pack and esc on side pod. Shaved brace (Yaiba racing) with rear hub (metal Yaiba) equal to a "C"
2 deg antisquat
Metal bulk head up front. The rest is pretty much kit setup include full ballast weight rear.
I am trying to get rid of a slight push on power corner exit. The rest is perfect.
Just need to know which setup the B4 platform responds to the best
zzztech is offline
Old 07-14-2013 | 10:26 PM
  #6803
mmm, antisquat?
Toyman is offline
Old 07-14-2013 | 10:31 PM
  #6804
Originally Posted by Toyman
mmm, antisquat?
2 deg. What's mmm?
zzztech is offline
Old 07-14-2013 | 11:16 PM
  #6805
metalnut's Avatar
If I plan to run a shorty pack and put the ESC in the rear behind the battery, is there any reason not to stick the ESC to the chassis, thus keeping the COG low? I'm aware of the AE centered ESC mount, but if I have room on the chassis, do I really want to mount the ESC that high?
metalnut is offline
Old 07-15-2013 | 12:07 AM
  #6806
Unless you are running at a ROAR sanctioned event, you do not need the ESC mount. I prefer mine with the ESC and receiver in the tray, but that is my personal favorite.
Team G Racing is offline
Old 07-15-2013 | 12:11 AM
  #6807
Venom1836's Avatar
Images of Maifield's B4.2 at Chico
Do you know where I can find his setup for this race?
Venom1836 is offline
Old 07-15-2013 | 04:03 AM
  #6808
bds81175's Avatar
Moderator
mmm, antisquat?
I think he was suggesting that you change your anti-squat to reduce the push. I would try going to 3° and see how it feels to you. I know my initial post said decrease but I was thinking so hard on how to spell "titch" I got it backwards.
bds81175 is offline
Old 07-15-2013 | 06:10 AM
  #6809
Matt Trimmings's Avatar
Seeing as this race just finished about 12 hours ago you will have to wait and see if AE puts it up on their site in the coming days/weeks.
Matt Trimmings is offline
Old 07-15-2013 | 07:33 AM
  #6810
Works fine that's how I run mine. Take off the rear T-Plate and mount the esc as far back on the chassis as you can. Reassemble, use foam pad between battery and esc and behind esc. Mounting it on a shelf does give it noticeably more roll.
chevmaro is offline
