8T 2.0
Old 07-08-2013 | 07:27 PM
  #15706
Jiggawatt's Avatar
3.0 steering rack is smooooth!
Jiggawatt is offline
Old 07-08-2013 | 10:08 PM
  #15707
hey guys is the 8ight t 2.0 still good to race against other brands I heard that from my lhs that tlr is getting rid there race kit version
RavensNightFury is offline
Old 07-08-2013 | 10:38 PM
  #15708
mourinho's Avatar
Anybody know why the rpm/speed telemetry might not work on a 8t 2 rtr dx3s? The rx volt and the heat telemetry show up and work fine, but for some reason the speed/rpm doesnt move at all... everything is plugged in properly etc but it has never worked since new.
Its most likely something very simple I am overlooking so any tips would be appreciated.
mourinho is offline
Old 07-09-2013 | 03:22 AM
  #15709
Yes the tlr 2.0 is a very good truggy for racing.
now on that note how are you guys keeping the cv joint lubed. Mine start squeaking about 3 to 4 minutes in on the first run. I clean my truck after every day l use it. I tried dry wax lube but that didnt help much. I drive on very dusty tracks
e-fanatic is offline
Old 07-09-2013 | 01:09 PM
  #15710
Integra's Avatar
which CV's you talking about ? wheel CV's are not possible, but center's can be "booted" and sealed with Silicone or Shoegoo
Integra is offline
Old 07-09-2013 | 03:07 PM
  #15711
Wheel. I sealed and lubed the center already. The wheel cvs are squeaking bad.
Old 07-09-2013 | 03:46 PM
  #15712
2-shot's Avatar
Just a thought, but I wonder if a high tack chain lube would work? Maybe something for a dirt or street bike. It will attract a ton of dust and dirt, but it should stay on and not fly off.
I've never used a dry wax lube, so I'm not sure how tacky it is. Maybe grab a can of tacky chain lube and try it, or borrow a couple squirts from someone that has a street or dirt bike.
2-shot is offline
Old 07-09-2013 | 06:43 PM
  #15713
We have a bike/ATV place in town. Will pick a small can up and try it.
Old 07-09-2013 | 07:07 PM
  #15714
2-shot's Avatar
Keep us posted on how it works out for you. I'm curious to hear if it does help or fixes your problem. If it works, I may end up picking up a small can myself! LOL!!!
At which end of the CV are you getting the squeak? The wheel end, or at the outdrive cup on the diff?
2-shot is offline
Old 07-10-2013 | 03:49 AM
  #15715
Wheel end.
Old 07-10-2013 | 05:11 AM
  #15716
rubiconon37's's Avatar
The optical trigger on the flywheel probably has fallen of so the pick up has nothing to read. Very common. It won't las on the flywheel for long. It's just a reflective sticker.
rubiconon37's is offline
Old 07-11-2013 | 05:54 AM
  #15717
Integra's Avatar
Unfortunately it is what it is, and if you run in Dusty dry condition's your going to have to service your shafts more often if you want to keep them squeaky clean.
Integra is offline
Old 07-11-2013 | 04:09 PM
  #15718
BlueStreakOne's Avatar
Maybe if they weren't so squeaky clean they would not be so squeaky!
BlueStreakOne is offline
Old 07-11-2013 | 07:18 PM
  #15719
mourinho's Avatar
Yep your right mate, cheers!
Sorted
mourinho is offline
Old 07-12-2013 | 06:05 AM
  #15720
Integra's Avatar
Integra is offline
