SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 07-04-2013 | 08:28 AM
  #3856
MarqueeRc's Avatar
Originally Posted by mxnickj
hey guys... quick question. I have a race this weekend on a bigger outdoor 1/8 track and my ball diff won't be here in time so whats a good weight diff oil to put in the gear diff. Running stock motor/esc in a RS RTR.... track is semi loamy dirt with no blue groove or clay. Just looking for a good starting point!! Thanks guys!!
Anything from 1000-3000 diff oil would do well in those conditions, especially feel better than that thick grease used stock out of box for the rtr's. The grease is equivalent to about 10000 diff oil, not good for loose tracks.
MarqueeRc is offline
Old 07-04-2013 | 11:59 AM
  #3857
Originally Posted by mike0203
can someone tell me a starting point with the spur and pinion gear setup on my sc10 2wd. I have a hobbywing 3500kv 10t motor.
I would start with 20/87 and go from there.
theblitzkidd is offline
Old 07-04-2013 | 12:55 PM
  #3858
RC-ZOMBIE's Avatar
Anyone interested in a FT SC10? Brand new never seen a motor. Comes with Jconcepts 12mm axle/hub conversion and 12mm clamping hexes, FT blue batt thumb screws and white RPM ball cups. would like to get $245 shipped Because of upgrades. Note: no wheels or tires included.
Photos avail just can't upload for some reason.
RC-ZOMBIE is offline
Old 07-06-2013 | 02:25 PM
  #3859
Does anyone know if the J Concepts Rulux3332 SC10 12mm hex wheels - 2.2" x 3.0" will fit on my 12mm conversion or do i "have" to buy their J concepts conversion? I ask because I just bought a roller with the hex conversion with the bearings inside the knuckles. The hexes are plastic with the lips so im pretty sure they are AEs. I want to keep the original offset. All help is appreciated I need to order my wheels so I can race next weekend.
mike0203 is offline
Old 07-06-2013 | 02:47 PM
  #3860
Yes they will work. All conversions are 12mm.
astarback is offline
Old 07-06-2013 | 02:52 PM
  #3861
Thanks! just needed the clarification. Seems like they are implying only their adapter will work with the wheels.
mike0203 is offline
Old 07-08-2013 | 12:20 PM
  #3862
Default Sc10 Arms
Was wondering can I change Front A Arms to the 10.2 Arms using the old shocks...
dolfns1 is offline
Old 07-08-2013 | 12:41 PM
  #3863
motofreak32's Avatar
Yes you can but you also need to change the front shock tower.
motofreak32 is offline
Old 07-09-2013 | 05:04 AM
  #3864
mxnickj's Avatar
And the front body mount also I believe, right?
mxnickj is offline
Old 07-09-2013 | 01:58 PM
  #3865
beedee's Avatar
Not necessarily. There are pix floating around in the SC10 Part 2 thread of people getting crafty with the regular body mounts. They just drilled new holes in the new tower or something along those lines.
I have a RTR RS SC10 that I acquired for free, so I threw some money at it, picked up the big bores, new shock tower, arms and body mounts. The new mounts line up pretty much exactly the same as the old mounts did.
beedee is offline
Old 07-22-2013 | 06:37 PM
  #3866
Does anyone know if there is a rebuild kit for cva's? All i can find is a kit for the 4x4. I dont think that would work?
Thanks for any help
Old 07-22-2013 | 07:13 PM
  #3867
Thanks for any help
http://www.amainhobbies.com/product_...d-Kit-B4-T4-GT
Old 07-28-2013 | 05:35 PM
  #3868
Default ft 2wd
I have an ft 2wd sct with a 17.5 in it. I seem to lose the back end it kicks out so easy. This is on a lose bumpy blown out track today. how do you guy tie down the back end. i have no sways on the truck. i was running the shock limiters but im thinking on taking them out. i felt like i was fighting the truck the whole time never ran this on black dirt before. the 4x4 took good to it. What gearing are you guys using for the 17.5 i have a novak. and two of the people that claimed the were 17.5 and none boosted were smoking us the straight. Im at 28 p and 75 spur i think motor temp was 112 with 60 degrees outside today. i did traction role the truck in one spot a couple of time. If i put the battery in the back it got really bad. i move the shock out on the tower to the last hole seem to help a little. Any input would be good.
imrob is offline
Old 07-28-2013 | 05:40 PM
  #3869
Red78's Avatar
Check to see if your diff needs to be tightened
Red78 is offline
Old 07-28-2013 | 05:43 PM
  #3870
It sounds like u need different tires. Also are u losing it in the corners or the straights?
