8T 2.0
Old 07-04-2013 | 11:15 AM
  #15691
sickpuppy1's Avatar
now for someone who feels adventuerous, after you put the washer on, find a aluminum nut,probably 1/4" or 3/8" and thread it on the wing mount post, it will cut its own threads. after they are cut, you can use a nylon nut if you wish.......easypeasy!
sickpuppy1 is offline
Old 07-04-2013 | 03:39 PM
  #15692
2-shot's Avatar
Originally Posted by sickpuppy1
Guys, I went to amain and just did a search on "wing washers" and came up with this.
http://www.amainhobbies.com/advanced...ashers&x=0&y=0
Yeah, that's where I saw the TLR22 wing washers. I don't know if they'll fit. I would think they should work, as long as the posts are the same (or close to the same) diameter as the 8T 2.0 posts.
I'll get a pack of them and try it.
2-shot is offline
Old 07-04-2013 | 03:44 PM
  #15693
2-shot's Avatar
That's a cool idea!!! I have threading dies in those sizes. I could use a die and cut the threads in the posts. Then, like you said, get a nylon nut to thread on.
I like that, gonna have to try it!
Thanks for the idea and input!!!
2-shot is offline
Old 07-04-2013 | 08:07 PM
  #15694
jnorwood_losi's Avatar
double post
jnorwood_losi is offline
  #15695
GUYS....Tekno RC makes a wing mount specifically for the 8ight to allow for the wing to be screwed in. Comes with EVERYTHING needed!!
http://www.teknorc.com/shop/tkr4435-...e-heightangle/
Old 07-04-2013 | 10:17 PM
  #15696
KingdomRacer's Avatar
Originally Posted by 2-shot
Yeah, they only come with new wings, as from what I've found. I wonder if there's something else I could use? I wonder if the plastic body washers would work, or would they be too thin?
Maybe I'll hit the wanted section and see if anyone has some extras they would sell.
Thanks again for your help Gsnow39!!!
What color are you looking for?
Got some extra yellow's...
KingdomRacer is offline
Old 07-04-2013 | 10:20 PM
  #15697
I used to run this in my flashlight and I liked it a lot but it is a lot of unneeded extra weight in a nitro.
Old 07-05-2013 | 04:34 AM
  #15698
sickpuppy1's Avatar
I am a big Tekno fan, believe me, but I had that wing mount and after a few messed up landings, it was warped and ended up going back to the Losi mount.
Old 07-05-2013 | 05:51 AM
  #15699
Integra's Avatar
Ive ran the Tekno and a custom drilled Losi mount with nuts and IMO the Stock mount works just dandy in stock trim.
get some good body clips for the wing and you shouldn't be loosing your wing all the time (that is unless your a crash monkey)
Integra is offline
Old 07-05-2013 | 08:29 AM
  #15700
2-shot's Avatar
I really don't want to invest $50 into the Tekno rear shock tower and wing mount, just so I can attach the wing with screws.
I'll buy a pack of the TLR22 wing washers and see if they will work. I'll stick with the stock Losi wing mount. They're reasonably cheap to replace if needed, and I don't have to change my shock tower.
2-shot is offline
Old 07-05-2013 | 09:55 AM
  #15701
The Tekno wing mount bolts right up to the stock rear tower, the one's I owned always did...
But stick with the Losi stock wing mount.
Old 07-05-2013 | 10:13 AM
  #15702
2-shot's Avatar
Oh, ok.. On the Tekno site, it says you need the Tekno rear shock tower for the wing mount. That's what I was going by. I guess the $15 mount isn't so bad then, if you don't actually need their rear shock tower for it to work.
I agree, I think I'm gonna stay with the stock Losi wing mount. There has been more "cons" posted than "pros" regarding the Tekno wing mount.
Thanks for all of the input!!!
2-shot is offline
Old 07-06-2013 | 06:57 AM
  #15703
Integra's Avatar
Bonus to the stock losi mount is that it tells you when its tired and needs replacing, the Mount arms will start to tweak and bend in a "S" shape, Once they've been fully tweaked is when i see them break the most. The Tekno mount while it wont tweak as easily as the losi will, It still can fail.
Integra is offline
Old 07-08-2013 | 01:09 PM
  #15704
Has anyone tried the new droop screws from the 8ight 3.0 on their 8-T? I need to replace mine and was wondering if the new ones would work.
kawi650 is offline
Old 07-08-2013 | 06:50 PM
  #15705
nickdawg18's Avatar
No but i do have the 3.0 wing and the 3.0 king pins!
nickdawg18 is offline
