SC10 Thread Part 2
#3856
hey guys... quick question. I have a race this weekend on a bigger outdoor 1/8 track and my ball diff won't be here in time so whats a good weight diff oil to put in the gear diff. Running stock motor/esc in a RS RTR.... track is semi loamy dirt with no blue groove or clay. Just looking for a good starting point!! Thanks guys!!
#3858
Anyone interested in a FT SC10? Brand new never seen a motor. Comes with Jconcepts 12mm axle/hub conversion and 12mm clamping hexes, FT blue batt thumb screws and white RPM ball cups. would like to get $245 shipped Because of upgrades. Note: no wheels or tires included.
Photos avail just can't upload for some reason.
#3859
Does anyone know if the J Concepts Rulux3332 SC10 12mm hex wheels - 2.2" x 3.0" will fit on my 12mm conversion or do i "have" to buy their J concepts conversion? I ask because I just bought a roller with the hex conversion with the bearings inside the knuckles. The hexes are plastic with the lips so im pretty sure they are AEs. I want to keep the original offset. All help is appreciated I need to order my wheels so I can race next weekend.
#3865
Not necessarily. There are pix floating around in the SC10 Part 2 thread of people getting crafty with the regular body mounts. They just drilled new holes in the new tower or something along those lines.
I have a RTR RS SC10 that I acquired for free, so I threw some money at it, picked up the big bores, new shock tower, arms and body mounts. The new mounts line up pretty much exactly the same as the old mounts did.
#3868
I have an ft 2wd sct with a 17.5 in it. I seem to lose the back end it kicks out so easy. This is on a lose bumpy blown out track today. how do you guy tie down the back end. i have no sways on the truck. i was running the shock limiters but im thinking on taking them out. i felt like i was fighting the truck the whole time never ran this on black dirt before. the 4x4 took good to it. What gearing are you guys using for the 17.5 i have a novak. and two of the people that claimed the were 17.5 and none boosted were smoking us the straight. Im at 28 p and 75 spur i think motor temp was 112 with 60 degrees outside today. i did traction role the truck in one spot a couple of time. If i put the battery in the back it got really bad. i move the shock out on the tower to the last hole seem to help a little. Any input would be good.
#3870
24Likes
