Team Associated B4.2 Thread >
Like Tree4Likes
Old 06-22-2013 | 01:01 PM
  #6301
Jake S's Avatar
i had a few pms about how the new bulldog and the finnisher compare, i wont be able to run them back to back till wednesday tho... so i took some pics with my phone to show how they are different....
Jake S is offline
Old 06-22-2013 | 01:07 PM
  #6302
Cridd's Avatar
Originally Posted by DanielC.
Definitely go with the 1/8 out setting. I'd say at the MOST maybe 1/4 turn out. 1/8-1/16 is the norm.
+1
Cridd is offline
Old 06-22-2013 | 01:09 PM
  #6303
Cridd's Avatar
Originally Posted by Waflet
Hideeho
I believe your dif might be slipping rather than your slipper. The 1st page in this thread has a link to racer53's article about how to build a dif. He also did a video of the common sounds from a transmission. Look up racer53 on YouTube & watch that video. It should help diagnose the difference between a slipping dif & a slipping slipper.
P.s. if you find it is the dif slipping & you have the stock balls, you probably need to rebuild your dif with new balls & flipped rings. For the new balls, we have had lengthy discussions about the differences between ceramic & carbide. I, & others, like ceramic, still others like carbide. I would recommend buying one type now & the other type next time & decide for yourself.
I have rebuilt all my diffs with the MIP rebuild kit and everything works longer and better. The MIP topshaft is great too.
Cridd is offline
Old 06-22-2013 | 01:12 PM
  #6304
Cridd's Avatar
Hideeho
Just did a quick search & as far as I can tell ROAR still has the d3.5 17.5t on the ban list. Your track (along with lots of others) may not follow ROAR rules to the letter.
is that the Maxilla motor here?
http://www.amainhobbies.com/product_...que-Rotor-175T
Cridd is offline
Old 06-22-2013 | 01:15 PM
  #6305
Cridd's Avatar
the killshot goes to like 80* timing on the bell right? A buddy ran it in 17.5, said he loves it for blinky.
Cridd is offline
Old 06-22-2013 | 01:44 PM
  #6306
aeRayls's Avatar
The trinity motors have "true zero" in the motor itself. That's why it goes up so high.
Novak and a lot of other motors have 30* of timing inside the motor already.
aeRayls is offline
  #6307
the incubus's Avatar
JConcepts 4.2 & 44.2 cab forward design = FUGLY IMPO.
I find Proline's design to be far better looking, though I much prefer the traditional look better. Cab forwards simply look almost alien like.
the incubus is offline
Old 06-22-2013 | 01:56 PM
  #6308
PIIHB!'s Avatar
I like the old style buggy bodies better than whats out today
I want to order that MIP topshaft when my current gears wear out but that might be awhile
PIIHB! is offline
Old 06-22-2013 | 01:58 PM
  #6309
I prefer cab forward bodies. Gives it a fiercer look
Team G Racing is offline
Old 06-22-2013 | 02:22 PM
  #6310
From a driving perspective I found Finnisher body to be much smoother in high speed than the old Bulldog. Lets hope the improved V2 Bulldog drives better than the old dog
zzztech is offline
Old 06-22-2013 | 02:29 PM
  #6311
im kinda done building the buggy.
but i have a problem that only one of the 4 shock bushings is in the correct size. so i have only one shock mounted...
ebay007 is offline
Old 06-22-2013 | 03:27 PM
  #6312
Jake S's Avatar
i have a finnisher before big bores.... from the bulldog v1 to v2, it gained alot of high speed stability, and the wing was a big improvement over anything else they had....
i have been running the v2 bulldog for over a month, and like it, just want to try the finnisher again with big bores.
Jake S is offline
Old 06-22-2013 | 03:39 PM
  #6313
YankeeFan123's Avatar
I'm not good enough to FEEL a difference but I like the way the Finnisher looks on the truck and the buggy over the Proline Bulldog
YankeeFan123 is offline
Old 06-22-2013 | 04:55 PM
  #6314
aeRayls's Avatar
Just take some 1000 grit sandpaper to the ball on the bushings. Clears the problem right up.
aeRayls is offline
Old 06-22-2013 | 09:36 PM
  #6315
Skillz_B's Avatar
On 8th scale the cab forward dosent bother me as much, but for 1/10 I agee they are funky looking. Maybe it is the proportions, I think my next body will be the Interceptor 2.0 which is +8mm for the B4.1 & 2. That or a Jconcepts Punisher or Illuzion Scoopless, but I am partial to the Interceptor 2.0.
Anyone running the Trakpower ESC or Motor, the new Car Action has a first look, but there isnt much info on them.
Skillz_B is offline
