Like Tree5Likes
SC10 4x4 Thread
Old 05-09-2013 | 09:30 AM
  #33961
Wild Cherry's Avatar
Originally Posted by Kromulous
Tore my truck down to last screw last night. I bought one used, got a good price so i can sink plenty of $ in it and upgrade it to how i like it.
Anyway, i noticed the diffs and the interior of the case is all full of the diff grease. It really bogged down the rotation of the drive line. So is there anyway to keep the diff grease contained in the diff? or did they use to much and it bleeds out all over the place?
Thanks, Krom.
Do not fill the case all the way.
only 3/4 full will help the oil stay inside
25 to 30 k front diff
5 to 7k rear
Wild Cherry is offline
Old 05-09-2013 | 09:46 AM
  #33962
5 to 7k rear
So you fill the inside of the actual trans case? not inside the diff?
Wow interesting, seems like it really bogs the trans down, free spin wise.
25k to 30k diff grease in the front?
OK, will give it all a try, sounds like i may buy a couple xtra trans from ebay and swap em in and out maybe.
Thanks, Krom.
Kromulous is offline
Old 05-09-2013 | 09:56 AM
  #33963
kromulous
oil only goes into the diff cases , leave the transmission cases dry .
Extra transmission case not needed,spare diff cases maybe
Old 05-09-2013 | 10:01 AM
  #33964
Dup
Old 05-09-2013 | 10:05 AM
  #33965
Cain's Avatar
Gonna be running the RCshox center diff btw.
You want 7K - 10K in the front diff, NOT 25K to 30K, that is the setting used with the VTS slipper.
5K in the rear is what I would use as well.
For pins, start with 4.
Cain is offline
Old 05-09-2013 | 10:55 AM
  #33966
Got it, thanks all, more questions to follow LOL.
So far i like it, cant wait to run it, never owned anything 4 wheel drive, and in all these years.
Krom.
Old 05-09-2013 | 11:01 AM
  #33967
Cain's Avatar
Its a fun vehicle for sure!
Cain is offline
Old 05-09-2013 | 11:32 AM
  #33968
Thumbs down
what are these pin you guy are talking about got a pic anyone thanks rob
imrob is offline
Old 05-09-2013 | 11:50 AM
  #33969
TomErickson's Avatar
They are specific to the RC Shox center diff for the SC10 4x4. They adjust the diff action. See link below:
http://www.rcshox.com/sc1044-center-dif-v2/
I want to get one to try it out someday. I hear this is one of the key upgrades for this vehicle. More pins means stiffer action much like thicker fluid in a standard gear diff.
TomErickson is offline
Old 05-09-2013 | 11:52 AM
  #33970
Cain's Avatar
Cain is offline
Old 05-09-2013 | 01:24 PM
  #33971
I put 60k in the front. Works good
cobra408 is offline
Old 05-09-2013 | 07:49 PM
  #33972
neospirit's Avatar
I try to search, but didn't find anything. After I put the spur gear on and tightened the clutch per the instruction, I cannot turn the spur gear. Am I doing something wrong?
neospirit is offline
Old 05-09-2013 | 08:12 PM
  #33973
neospirit's Avatar
Found the problem. One of the screws for the motor plate was too long. It was grinding the back of the pulley.
Old 05-10-2013 | 01:08 PM
  #33974
1 is a different length to the other two.
Take all three out and use the manual to put them in the right holes.
Don't do them up tight. Nip them up and check the diff still rotates freely.
If you crank them up you will crush the gearbox and bind it up.
Beachbuggyphil is offline
Old 05-11-2013 | 06:46 AM
  #33975
ok got it thanks guy. i just orded the upgrade kit for mine so i guess this might have to wait. i have never heard of this companany before looks like some good parts. i think i might try the vts4 disc plates or is that diff kit a must for 1/8 outdoor tracks. i think i got my car setup good but not great. i might try for this too. [I] have the stock sc10 with sway bars. that is all.
imrob is offline
