SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 04-02-2013 | 07:15 PM
  #3331
heavyjeffd's Avatar
Whatchoo talkin' bout Willis?
heavyjeffd is offline
Old 04-02-2013 | 07:22 PM
  #3332
matt*strike's Avatar
I have never had a problem with my savox servos and my spektrum radio you just have to have the dsm2 recievers like sr3100 or sr3250.
matt*strike is offline
Old 04-03-2013 | 07:22 AM
  #3333
I'm having trouble with my SC10rs pushing through tight hairpins. It just wants to understeer horribly at low speeds. I have to crawl through the tight corners or it will just push wide into the berm.
The track best described as cleared dirt and gravel. Somewhat hard base, but still soft enough that the rears can dig in and leave small tracks in the exits. There is no competitive racing going on, just a home built track for my buddies and I to race on. Nobody has any real experience so asking them for setup tips is a moot point.
I'm running the stock fronts with Proline Gladiator SC rears, not sure if it is the tires or suspension setup, but any suggestions would be appreciated.
nofreee is offline
Old 04-03-2013 | 07:23 AM
  #3334
Double post, sorry.
nofreee is offline
Old 04-03-2013 | 07:45 AM
  #3335
Wildcat1971's Avatar
Tech Prophet
the stock front tires are horrible. I would start there. you can also try to soften the front up with springs and oil.
Wildcat1971 is offline
Old 04-03-2013 | 10:23 AM
  #3336
He sai he has understeer probes, I thought stifening up the front( thicker oil, and stiffer spring) was supposed to be a remedy for understeer, not softening, unless I'm mixed up
theblitzkidd is offline
Old 04-03-2013 | 10:27 AM
  #3337
Tech Prophet
under steering is push. normally caused by bad tires or not enought weight transitions forward. To get more weight moving forward you soften the front. Stiffening the rear can also help. You can also remove some droop in the front. many things to do, but the rtr front tires dont have much bite. I would swap those out.
Old 04-03-2013 | 10:35 AM
  #3338
Ohhh well learn sumn new everyday and yeah the front tires don't bite on pavement even lol so they r a must to change, something like carvers or goosebumps r good
Old 04-03-2013 | 01:03 PM
  #3339
I'll start with the tires.
Caliber M3's was what I am leaning towards.
nofreee is offline
Old 04-03-2013 | 02:05 PM
  #3340
Tech Prophet
calibers are a decent all round tire.
Old 04-03-2013 | 02:45 PM
  #3341
I'll give them a whirl. Thanks for the help.
nofreee is offline
Old 04-03-2013 | 03:08 PM
  #3342
Nicholas Muelle's Avatar
What kind of track?? Dusty,smoth, high grip??
Nicholas Muelle is offline
Old 04-03-2013 | 03:51 PM
  #3343
Tech Prophet
Its a backyard track
Old 04-04-2013 | 06:01 AM
  #3344
Ohhh, i wish i had a track in my back yard
Old 04-04-2013 | 08:08 AM
  #3345
Effectively. It's on some graded land that hasn't been developed on for nearly 5 years now.
It is dusty and fairly loose. It has a hard base, but the dirt still shifts around, particularly on the turns.
nofreee is offline
