Tools???
Old 04-01-2013 | 05:09 PM
  #16
justpoet's Avatar
I used to think decent tools were good enough.
Now I swear by MIP for my drivers. Don't skimp on the hex drivers, especially the smaller ones.
justpoet is offline
Old 04-01-2013 | 05:21 PM
  #17
TheRcKid17's Avatar
I like the protek ones but they are a little pricy, if you want to go cheap the dynamite ones are a pretty good deal.
TheRcKid17 is online now
Old 04-02-2013 | 07:56 AM
  #18
Salinas Hawk's Avatar
Here are the fake Hudy Ultimate Body Scissors. Again, the package only had one staple instead of four like it should. I was able to slide them out of the package and inspect both sides. They felt heavy and there was no Hudy logo.
I quickly snapped a pic before sending them back; my bad for the glare.
Salinas Hawk is offline
Old 04-02-2013 | 08:17 AM
  #19
Here is the real McCoy. Check the Hudy logo.
Old 04-07-2013 | 01:05 AM
  #20
Droop and Ride Height.
1. Can I use the same tool to measure droop and ride height on 1/8 and 1/10 buggies?
2. Who knows where zero droop is anyway?
Is the height of the blocks that go under the chassis equal to zero droop?
3. What good is a 17-30mm Hudy ride height kit when all my buggies have more than 30mm ground clearance? what am I missing?
http://www.hudy.net/xhudy/products/p...3&kategoria=64
Old 04-08-2013 | 05:14 PM
  #21
justpoet's Avatar
Ride height is ground clearance when you set the vehicle to sit on the suspension on a flat surface.
Droop height is ground clearance when the suspension is fully uncompressed.
Most people measure "droop" by going eyelet to eyelet on the shock. I personally like the method of measuring droop by lifting the car until the wheels leave the table and measuring that height. Both are correct, but you can't match a setup sheet that uses one method by using the other.
For racing, most ride heights will be in the 20-25mm range off road (slightly more in 8th scale). Carpet will be even less than that, and on road goes around 5mm.
justpoet is offline
Old 04-17-2013 | 12:47 PM
  #22
Ahhhhh thanks
I have just about everything except set up tools. I even got the Arrowmax shock pliers. They are nice.
Question. Is the Losi shock matching tool useful?
Old 04-17-2013 | 03:23 PM
  #23
blis's Avatar
Originally Posted by Salinas Hawk
Ahhhhh thanks
I have one, we rarely use it.
blis is offline
Old 04-18-2013 | 03:05 PM
  #24
Voltage_Drop's Avatar
Nobody ever mentioned a Dremel. I cant count how many times a dremel has helped me to remove stripped screws heads, and make custom modifications. It is one of the most valuable tools in my box.
Voltage_Drop is offline
Old 04-20-2013 | 09:03 PM
  #25
asc6000's Avatar
dremel never gets unplugged. Clean out the hex heads and use a quality tool and you won't strip out any heads. Mip hex drivers.... 20 years old and still like new. Like the handles better than the alu ones as well. Tools are an investment.
asc6000 is offline
Old 04-23-2013 | 05:00 PM
  #26
Yes, I completely agree, quality tools are a good investment. I have more than enough tools than I really need. I was just saying that the dremel is perfectly suited for modding ventures, which I do quite frequently.
Old 05-22-2013 | 02:06 PM
  #27
goatsblood666's Avatar
The Dremel never runs out of uses!!!
goatsblood666 is offline
